I am, me too, a big fan of these little MS1202 .
They are indeed very punchy and especially very customizable
I already solved the very common left rigt problem by redoing the power supply.
I replaced the 7815 and 7915 by lm317 and 337 and rised the voltage to +16,8V/-16,8V. I changed the caps for panasonic FM.
On the main board, i replaced all the caps with Panasonic FM of the same value and all the 22uf (mostly in the signal path) with 47uf.
After few hours of work i have now a perfect left/right balance, a bit more headroom and a much more silent and better sounding mixer.
The second mod was a insert on the master bus and a mute switch on every channels
I am now working on adding a sub group with insert.
Living sounds..... i am very curious about swaping ic's.
How do you like the sound of it now you have replaced the 4560 by 5532 ?
I must say that i quite like the dirtiness of the 4560.
Best
Greg
