mrphotodude
looking for phantom supply self etch pcb image
« on: January 31, 2009, 07:07:56 AM »
yes, title says it all....
i have some preamp psu's with phantom on them ect...but wanted to find a standard already good designed phantom power pcb trace image.
Is the soft start any good?
http://www.diyfactory.com/projects/softstartphantom/softstartphantom.htm
or this unit?
http://sound.westhost.com/project96.htm
or any recommendations you can throw out.
How much current is really needed for a single mic's phantom power? I assume i can use a tiny transformer for a single mic if needed yes?
another day...another dalek
pucho812
Re: looking for phantom supply self etch pcb image
« Reply #1 on: January 31, 2009, 01:17:39 PM »
average per one channel 10 miliamps IIRC
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
mad.ax
« Reply #2 on: January 31, 2009, 02:44:55 PM »
Worst case scenario hapens when both hot and cold are shorted to the ground (trough the 6K8 resistors), then I=U/R...
48/6800 = ~7mA, multiply that by 2 (cause there are 2 X 6K8) = 14mA. So, assume 15mA per channel, and you'll be fine.
Axel
Last post April 10, 2012, 01:46:08 PM
by spase
Last post May 12, 2010, 06:44:11 PM
by juanjovincenzo
Last post March 28, 2012, 02:11:35 PM
by zayance
Last post June 05, 2013, 01:46:40 PM
by EmRR
