zayance
Re: PGA2500 KITS: AVAILABLE. BLACK PCB, SUPPORT THREAD.
« Reply #60 on: November 16, 2009, 05:12:07 PM »
Ok, you mean 6PCB's left that i will have to solder the PGA by my own right, and maybe another batch for next year for full kit, but no PCB pre-soldered?
« Reply #61 on: November 16, 2009, 05:18:50 PM »
Exactly :)
http://www.ij-audio.com
(new site hopefully will be up in July)
zayance
« Reply #62 on: November 16, 2009, 06:57:32 PM »
Ok, well smd is not a technique i'm very used to, solder paste maybe can do the trick, with oven technique but a little too much for a novice i think  ::), i have a micro solder iron that could do the job, any advice?? how are you mounting it?
I'll be using 63/37 no clean. For doing the job right, i will need to put some solder first on the PCB and then put the Chipset and heat the legs no???, but what about the heat applied for a while until the 28 legs are soldered correcly??  will this cause a problem? I know the quicker the better but just asking... Thanks for helping out...
I was searching for a crystal clear type preamp, and this project is really cool, could build a nice 4 preamp in a 1U in the future, i just want to purchase PCB's before they are gone but haven't thought on soldering the chipset by my own, maybe it's time to try this, but let me think about it and will get back to you shorty, waiting for your advice...
« Reply #63 on: November 16, 2009, 07:24:12 PM »
Tony, the key is just a good iron with constant temp., 0.4mm solder, good liquid flux and magnification lense.
Search YouTube or Google for SMD soldering video.
After some time you will find soldering 100-pin SMD chip with 0.5mm step takes same time as soldering 10x 1/4W resistors.
zayance
« Reply #64 on: November 16, 2009, 07:35:05 PM »
Yep i was doing search right now, i think it's time to start SMD and i can test my skills before also on some smd resistors etc....
Ok so what would be your total price of 4 PCB's and PSU plus shipping to France then, without microcontroller. Thanks Igor!
« Reply #65 on: November 16, 2009, 07:51:36 PM »
Ahem... I guess you mean PGA2500 chip. I don't think you want enter into the mess with programming your own controller :)
The price already include microcontroller's price. It is same with or without.
This is BUILD SUPPORT thread. All questions about pricing, etc-here:
http://www.groupdiy.com/index.php?topic=29771.0
or by pm.
Let's keep building thread clean, just think about reading 150 posts to find info you need. Thanx!
Kir_For_Pleasure
« Reply #66 on: November 16, 2009, 09:36:28 PM »
Me likes !!! stunning work !!
Cheers !!
Thomas
Sweden
zayance
« Reply #67 on: November 17, 2009, 03:09:17 AM »
Sure no problem, thanks a lot
« Reply #68 on: November 17, 2009, 09:07:23 AM »
Cool than....will be happy to see photos of finnished stuff. Good luck!
rob_gould
« Reply #69 on: November 25, 2009, 09:52:54 AM »
Can anyone in this thread tell me where they got their PGA2500 chips?
They are out of stock at RS and Farnell in the UK, and Digikey and Mouser in the US, and not available until next year by the look of it.
Igor - know any reliable sources ? ;)
Studio furniture, modular synth cases and more...
www.gouldcaseworks.nl
« Reply #70 on: November 25, 2009, 09:59:32 AM »
Really....dunno. Try to ask Rochey.
12volts
« Reply #71 on: December 09, 2009, 07:33:35 AM »
The earliest you'll get any in the UK is the end of January 2010. then only if you ordered in October.
It is the same tale for any of the large UK distributors. They are being rationed too, 6 chips per customer.
This of course puts your order in the higher price band too, currently £22 each !!!!  Good job I bought 12 a while ago.
rob_gould
« Reply #72 on: December 09, 2009, 07:54:27 AM »
Mine are being dispatched direct from TI on 24th Dec apparently.
« Reply #73 on: January 02, 2010, 06:05:41 PM »
I got some through TI samples program........8 of them IIRC. Happy hunting.
janvanvolt
« Reply #74 on: January 07, 2010, 09:48:10 AM »
Just ordered the parts from reichelt + farnell. Can't await to get the PCB (and then to finish this lovely project).
zayance
« Reply #75 on: January 29, 2010, 05:29:29 PM »
Hi Igor, sorry to bother for this, but im having a hard time finding the 2 Row 8 Pin connector with housing  (SP1) for ribbon cable, do you have the Farnell Reference? I've searched on Farnell, Digikey... but can't get my hands on something that will fit. Thanks in advance.
zayance
« Reply #76 on: January 30, 2010, 07:09:29 AM »
Finally, seems i found something that will fit, sorry for that, don't know why it was hard for me founding this part  ??? , the most popular starts at 10 pin, this one doesn't have the exact same size of your connector, but i think it will do the job:
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=609-3083-ND&x=0&y=0
« Last Edit: January 30, 2010, 07:14:35 AM by zayance »
« Reply #77 on: February 01, 2010, 06:53:27 PM »
Yes, this will do the job, just check twice the pin orientation before connection :)
zayance
« Reply #78 on: February 11, 2010, 07:39:04 AM »
Oh i forgot to ask you something, i've also had a hard time finding the 50uf capacitor for C25/C26, i went for 56uf, i tought that with the tolerance this will be no trouble, but i just want to make sure, maybe i'm wrong? (i'm still a rookie in electronics) but i see that from the schema, these are related to the Common Mode Rejection pot, so changing the value could mess up this part ??? I said to myself electronic is not an exact technologie so.... Thanks Igor
PS: I'm still a rookie, but i have basic electronic skills, good hand and soldering skills and a lots of patience so i don't think this building will be too hard, like everything else beeing careful gets the job done,  so don't worry i'll check everything on my work and infos on prodigy to get my answers, i know that you're a busy man. Thanks a lot Igor
« Last Edit: February 11, 2010, 07:43:31 AM by zayance »
« Reply #79 on: February 11, 2010, 09:34:36 AM »
Tony, it's OK. These caps can be 47uF as well, like:
http://il.farnell.com/panasonic/eca1vam470x/capacitor-47uf-35v/dp/8767246
(for example, these caps are cheap, but have good performance).
Last post September 27, 2004, 11:40:41 AM
by Bauman
Last post October 14, 2020, 11:47:39 AM
by niconeemis
Last post May 30, 2020, 07:35:55 PM
by jasonallenh
Last post July 26, 2020, 07:16:09 AM
by Whoops
