D.I.Y. Completion Confessions List , made public
Winnipeg Mb Canada
Accountability through forum friends ?
list your next project or two with a timeline , let the
group do the rest , that is,  you might not rest until it is done
O.K. time to fess up then
WHAT is your next project [ or few , but in a commited order ]
to finish ?
I have to finish modding  [ tracing ] a ts-9 dx , so i can sell the Analogman
modded one for bigger bux , that i bought broken and fixed it .
-today feb 8 th so i can list it on fleebay
Next proaudio project cloest to completion is the NEQ ,
- give me to weeks end i'll check the parts status today
edited with dates Feb. 10th
rangeblaster stompbox (range master clone.)  - due: Feb. 28th, 2009
• get Neve 1272 racked and working (mostly finished) - due March 31th, 2009
SSL 9k - due: June 30th, 2009
API312 - due: Nov. 26th, 2009
I have 2 Pr&e voice processors (comp, exp?, eq, de-essers) that need to be racked. The comp section sounds cool. They have been in my closet for 3 years or more. All I need is to spring for a 1U chassis from par-metal and a front panel from PF express. I even have the FP Express order ready.
I suck.
i have two projects too
eqp1 dual
and meq
most parts i have shopped but next week i will get nearly all.
i have problems with shopping xs1100 and the right toroid tranny cause i do not understand
how i can set up a toroid with 230>250v,9v as i need 220v and 12v values ??? i hope i understand it anytime...
my deathline is yesterday  ;D ;D
edit:
as if i understand which toroid i need i will buy it the next time.
i want to be finished in end of march (30 March 2009)  ;D HOPE I WILL TAKE IT!!!
get the fp from dan for the 1176, pcb's and switches from Hairball and a meter and finalize the unit
make the 6 headphone amps (got all the parts :-[)
sort my fetboy (stuffed) and rack it as a front to the second 1176 i have stuffed and rack it.
sort the 4 greens i have
then its on to the othe projects i have knocking about.
time frame ... as money allows ... but asap
1176 with Dans fp to have pics posted by 13/04/2009 (my 42nd b/day)
Iain
Gentlemen , please add current expected completion date
VERY IMPORTANT
then we can hound you to finish
but more so you can do the completion backwards principle
or just priorise the steps you need to finish , and then you have the
goal of a specific date so you can gauge if your on track
they are all equal to me, its just time mainly thats my factor.
most important i supose is the hp amps, say 4 weeks? 08 march 2009
Iain
Please
!!!! If someone willing to help me with my toroid tranny situation !!!! i wrote it above...
i could finish it faster :) (tranny for gyraf srpp stage powersupply pcbs)
hotbaby said:
Please
Buy these for your dual.
1X  12V 50VA
http://www.antekinc.com/AN-0512.pdf
Or
1x 15V 50VA
http://www.antekinc.com/AN-0515.pdf
for the main power
2x 12V 20VA
http://www.antekinc.com/AN-0212.pdf
You could possibly use one of these to power it all
http://www.antekinc.com/AN-1T200.pdf
the 15V option makes the next transformer a little hotter so instead of 220 you get 240V and it's not always necessary.
If you use the 15v make sure the LM317 has a good heat sink..
so 220V in to 15V out, then 12V in to 220V out.
just like the drawings show...
thank you so much,.. i understand more now  :)  but can i use the musikding trafo and split 24v to 2x 12v? would be more easy to order (germany).
Oh god...I'll put a couple projected dates, but I can't put a timeline on all of mine.
4 channel green pre - 2 channels stuffed, 2 to go, faceplate and racking - Beginning of april
2 channel 312 - 1 stuffed, 1 to go, faceplate and racking - end of april
2 channel 1272 - nothing done
2 channel fetboy - 2 channels stuffed, faceplate and racking
2 channel s800 - nothing done
2 channel nite eq - nothing done
2 channels of 1176 - nothing done
Adding a date is what makes you commit
done the overdrive , i'll list it tonight
I'll pull out the neq and take inventory ,
start drilling chasis holes for standoffs
[ bit by bit , may be boring but one at a time ,
wins the race ? '
OK , good idea so here goes :
D-AOC - finish wire up, change Lundahl's to Edcors and test - end of this week !
Dual 1176 - boards are done, fit in case and wire up - end of the month ( Feb )
Dual LA2A - nothing done, have all parts and case - done by the end of March/early April
PM670 - nothing done, have all but the 220u 400v caps ( anyone have some ? ) - done by the end of May
( may have to do 4 x 9k' s for a mate, week after next so that could stall things a little )
Later on in the summer :
Another GSSL & Turbo
Finish racking my pair of 676a's
2 x 492's and 2 x S800 eq's to do !!
Second PM670 to do
Blackface 1176 to do
Headphone amp and Sumthing rack to make with Lawo summing card.
2 x NTP Limiters to rack up in a 1U case ( need front panel )
All "work" dependent on time/life etc  !!
MM.
Hey hotbaby instead of hijacking the thread you may want to take it to the lab
I'm trying the save the world & keep people accountable here
I made a lot of promises here a few years ago with the Calrec 1061 project.
I bit off more than I could chew at the time and had to go back to basic to learn, in the mean time a job etc got in the way. But I cannot rest until those promises are fulfilled.
First up - recap and rack a pair of originals I got over the summer as a 'reference'. This is a job for late feb, early march.
Second - complete the re-make of the 1061-1161 preamps with severe mods for the new Sahib/SilentArts 500 compatible rack. Just spent 500 quid more on parts and now have 5 input trafos plus 4 outputs to compare (20 combos including re-made originals from Sowter, multiplied by cap choices!) to create the BEST sounding preamp I can make, in reference to the original.
I was in chats with a pretty popular muso/producer who exclusively used 1061s on his last record for feedback to improve over the originals and may do a little listening session at his sometime if still welcome! Specifically looking to fatten and extend the bottom end, while retaining their punch and openess.
I am midway through re-doing the opamps with modern transistors. And have parts coming from Grayhill and Omeg as we speak. Hope to breadboard the amps during easter when I get time. Completely done by summer.
The rack has finally made it possible after a year of waiting for alternatives from SCA etc and attempting my own rack design which was far too ambitous (16 busses etc).
Once that is done I will:
A.) Do a 1061 eq version for the 500 rack or
B.) Carry on prototyping my console design which I did a lot of work on over christmas.
After that I have 2 EQ designs I am working on and a Neve/Pultec hybrid. Then the clones come PM670, DOAC etc haha
-T
Sorry Greg, t'was me who asked in ( brackets ) about the 220uf's  :-[
Tom - sounds like you have some interesting things to do, I kind of "bit off more than I could chew"
with a pair of 1073's and although the sets of boards are all done, I just don't quite know what to
do next ! ( have to fit each set into a 1U case too )
The £300 worth of required transformers gives me the "heebee geebee's" never mind the pots !!
MM
marty hotbaby went off on a transformer tangent , but
Sometimes i just have to sell off the projects that haunt me too long ,
makes my list shorter .....and sometimes the money goes to buying
other gear  [ the trades get me back in trouble though ]
Having or getting a faceplate made , is a sign of seriousness
then i know it can turn out good
And i'm watching y'all , gonna be policing this thread ,
HEY MARTY , What have you done lately  ?
