The tubed phono pre at MCS's site
mcs
Denmark
It should work, but you may need a regulated supply for minimum noise. I use a simple two transistors and a zener circuit. You could use an LM317HV or a TL783 also.
And unless you have the 6SN7/6SL7 tubes I would use the 12V types...
Best regards,
Mikkel C. Simonsen
I came up with this power supply many years ago...
http://stiftsbogtrykkeriet.dk/~mcs/Phono/PHOPSU2.gif
Complete with "assembly manual": :green: http://stiftsbogtrykkeriet.dk/~mcs/Phono/PHOPSU.gif
It was made for a cheap Hammond transformer (200V and 5V), which is not an option here (only 117V primary).
Best regards,
Mikkel C. Simonsen
