there is another way to measure output/input transformers..
http://www.harpamps.com/transformers.html
your secondary and primary will not have impedance between them...so find out which wires pair up first.
if there is a center tap, it is close to half of one of the sets.
i setup a variac with a wall wart and dial it in to 1 vac...
i put 1vac across the primary and measure the secondary.
then you divide the secondary voltage by the primary voltage and square it
so if you put 1vac on the primary, and get .5 on the secondary, you get 2, squared you have 4
so if you have a 150 ohm input you get 600ohms out.
its a 1:2 turns ratio
impedance ratio is the square of the turns ratio
if you got .25vac on the secondary, you have 4 or 1:4 turns ratio.
4 squared is 16.
16x say 600 ohm input is 9600(or 600:10k as it is usually stated).
hope that helps, if i am wrong somewhere here, let me know...but i have done this on plenty of known transformers and had it come out very very close to listed specs.
