2MB flash USB memory, where do I find it?
Val_r
Naples, Italy.
Recently I bought a Tektronix 2002b digital storage oscilloscope.
Surprisingly I read from manual that the front panel usb port is compatible only with a maximum 2Mb flash memory!
Is it still possible to find that?
Any hints?
perhaps it is possible to format any flash memory to have 2mb partition and rest of the memory unused? but I'd check if it works with the one you have cause I use 2Gb pendrive with tektronix oscilloscope and it works fine.
hey, apparently it's a typo in manual, it shoud say 2Gb:
http://www.tek.com/forum/viewtopic.php?f=5&t=244
Thanks for the quick reply!
I deeply hoped that it was a typo!!!
2Gb are easy to find.
I will try to create a 2gb partition as you suggested.
Thanks again.
Respect,
Val
After I googled partitioning a pendrive, I tried to do what you suggested, since I have a 8 Gb pen stick, so plenty of room for a 2Gb partition.
It seems that no software is able to do that.
I tried PartitionMagic 8, partition manager, from disc manager under Windows, but no luck.
Only hard drives were recognized, not my pendrive.
Some suggest to do that with fdisk under DOS.
I have never tried that, I do not know if it is possible to get FAT32 partitions....
Any lucky pendrive partitioner around?
Respect,
Val
So you're using windows, right? honestly I haven't been working with this system for quite a few years now so I have no idea what tools you can use.
