Re: 2254C build/support thread
« Reply #720 on: May 16, 2014, 09:03:00 AM »
Does anyone know the values of C19, R54 and R47 for the input transformer VTB9046 ?
Thanks  ;)
duantro
« Reply #721 on: October 04, 2014, 07:14:15 PM »
Thanks  ;)
I used the values in the schematics
dacapitan
« Reply #722 on: October 16, 2014, 01:45:43 AM »
can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...
when they short, its stereo... when they are no-short dual mono
EDIT : hope you matched your diodes an both units...
I am a bit confused with wiring up the Stereo/Dual Mono switch. I noticed there is a "Link" on the control PCB and a "LNK" on the mainboards too? - I am not sure if both of these are supposed to be connected to the switch?
The way I understand the quote above is depicted by "B" in my diagram - which is the correct way to wire this? A or B or Neither - Any help will be much appreciated!
duantro
« Reply #723 on: November 15, 2014, 02:09:53 AM »
I believe your b drawing is correct. To pull a quote from Reanimator's build docs: "can you see then "link" on control pcb ... you just put a switch to that, and connect to second unit...
when they short, its stereo... when they are no-short dual mono."
dacapitan
« Reply #724 on: November 16, 2014, 01:38:14 AM »
Hi Duantro,
Thanks for getting back to me on this - much appreciated! Sure, I read that in the build docs too - Just wasn't sure about the "LNK" on the main board. Thanks, I'll just use a SPDT switch to the control PCB then - thank you! :)
« Last Edit: November 16, 2014, 01:52:36 AM by dacapitan »
jaycee
« Reply #725 on: January 29, 2015, 01:07:31 PM »
Hi guys.
I have been building my 2254c, left channel works fine, the right one saturates a lot, I have to pull down the input saturation a lot to have a clear signal.
It seems the signal saturates at the b183.112 step, as I've tested by reinjecting the signal into the working channel at different steps.
So I've checked all components for this part of the amp, changed the transistors to new ones, it hasn"t changed anything. I've checked all resistors, the soldering...
Now about the voltages, I get 20Volts after R28 on this defect channel whereas I get around 7.5V on the channel that works... On the working channel R28 gets hot but well the channel seems to work properly...
I feel like I've tested everything and not found the solution.
Anyone has advices or voltage references I shoud get at the B183.112 part? I really don't wont to pay a local tech, but feel like I've spent hours on this problem already, any advice is welcome :)
JC
« Reply #726 on: May 02, 2015, 05:29:35 AM »
Can someone upload this again?
The build manual from Reanimatorstudio
The link is not working on the first page.
gainlab.co.uk
WE MAKE SOUND
duantro
« Reply #727 on: May 02, 2015, 08:28:33 PM »
PM or email me your email address and I'll send it over.
SIXTYNINER
« Reply #728 on: April 15, 2017, 03:13:53 PM »
.....long time ago he start a trhead about ....
but if i'm not wrong no much helps about....
 ;D
personally i'll go with this one
https://groupdiy.com/index.php?topic=62712.120
much recent , nice support , full help documentation ,
a so much better 2254  project (i.m.h.o.)  :)
ps:
..another "Igor" ?
hmmm.......  ::)
« Last Edit: April 15, 2017, 03:59:32 PM by SIXTYNINER »
>>" 1 Picture say what billions words cannot "<< - >>"SMD Kill the DIY STAR"<<
Why in the  forum  if no share
JayDeeP
« Reply #729 on: June 09, 2017, 10:42:49 AM »
Just thought I'd post another finished build.  Sounds fantastic.  I bought the ancient L0116a output transformers from Dan Alexander about 13 years ago.
madreza
« Reply #730 on: October 18, 2017, 07:37:36 PM »
Hi Guys
I'm trying to calibrate the beast .....
I'm stuck at that level :
"With the compressor switched in adjust GAIN trimmer to get unity gain."
I can't get unity gain .....   I'm -4.5dBs Under that what should I do ?
EDIT : Seems the problem is on 1 Channel ....
« Last Edit: October 18, 2017, 07:44:23 PM by madreza »
Knight 1: We are now no longer the Knights who say Ni.
Knight 2: NI.
Other Knights: Shh...
Knight 1: We are now the Knights who say... "Ekki-Ekki-Ekki-Ekki-PTANG. Zoom-Boing. Z'nourrwringmm.
madreza
« Reply #731 on: October 20, 2017, 12:56:55 PM »
Ok , still need some help on the calibration process
if someone can help ... :)
on my second channel I get -20dB on the XLR
but do I have to turn RV3 Till I get 0 on the VU meter ?
Knight 2: NI.
r2d2
« Reply #732 on: November 02, 2017, 04:38:17 PM »
…..That Neotek looks so nice  ;)
cheers
ps
what carnhill in the "mid" stage?
..... Cracking D.Vader Firewall ...  II-)
Last post June 04, 2019, 02:36:33 PM
by TubeMonkey
Last post April 23, 2019, 10:42:48 PM
by jsteiger
Last post January 25, 2013, 10:56:17 AM
by kato
Last post January 12, 2010, 05:42:42 PM
by sahib
