while fighting with the poor man (you see it on the back) , i had the time to finally finish this wonderful compressor !!
I have the second vactrol for soft setting and the parallel blu led for hard setting.
I've done the Kuby mods about caps, and used a 25W 330Ohm resistor before the regulator on the 245 Volt, because the trafo was spitting out near 280V.
Thanks to Analag, Volker, Kuby, and Marty (for the hints about the resistor ) !
