FINISHED DAOC with Kubi Mods-
AW_music
Italy
while fighting with the poor man (you see it on the back) , i had the time to finally finish this wonderful compressor !!
I have the second vactrol for soft setting and the parallel blu led for hard setting.
I've done the Kuby mods about caps, and used a 25W 330Ohm resistor before the regulator on the 245 Volt, because the trafo was spitting out near 280V.
Thanks to Analag, Volker, Kuby, and Marty (for the hints about the resistor ) !
Just one thing, you've left the BIG AC voltage "open" at your 25W resistor, you really should wrap
the lead ends in heat-shrink everywhere where there is "Raw" AC !!!!  ..... just incase !
MM.
MartyMart said:
Nice one !! and glad the resistor trick worked out fine :)
MM.
Hi MartyMart! what trick was that? I'm trying to figure out why my B+ is too high, dos this have anything to do with it?
Thanks.
