fuzzbox
1176ln rev.7 help
« on: November 06, 2004, 08:28:21 PM »
I was trying to adjust it according to the manual I downloaded from jbl.
Problem is my 20:1 and 12:1 don't work. When I depress one of those 2 it seems to bypass the limiter. I noticed C4 is alittle discoloured.(silver mica)
could this be what is causing the 2 ratios not to be functioning? I checked the voltage on the 2 test points in the manual. collector of Q8 should be +30v +/- 0.5 I'm getting +33v, neg voltage -10 +/-0.5 tested at case of IC1 I'm getting -9.8v.
Anyone have Idea's?
gyraf
1176ln rev.7 help
« Reply #1 on: November 07, 2004, 05:28:47 AM »
C4 should not have anything to do with that.
The ratio switches in 1176 does two things: It step-attenuates signal going to the rectifier (setting rectifier gain, thus ratio), and it adds a DC offset to the Q-bias (altering threshold so average compression stays more or less the same over different ratios).
My bet is that the ratio switches are either broken or dirty. Try cleaning them, and use your Ohm-meter to check that they work right. And while you're at it, check that connections to the main PCB are alright.
Jakob E.
fuzzbox
1176ln rev.7 help
« Reply #2 on: November 07, 2004, 11:29:49 AM »
Thanks Jakob,
It was a broken jumper on the switch. Not an easy find. The wire is a covered in a yellow plasic jacket, the jacket was stuck to the pin but the wire was broken. Thanks for the help.
Last post December 22, 2019, 03:21:59 PM
by Purplenoise
Last post May 03, 2009, 08:50:12 AM
by luis
Last post January 06, 2010, 11:04:08 PM
by listen202
Last post January 15, 2014, 10:01:32 AM
by poctop
