G-Pultec Input Transformer Issue
craigmorris74
GDIY Supporter
benton, ky
I'm testing out a G-Pultec filter section before I build the amp section.  I started with a Triad HS66 input transformer wired 1:1 with a 620 ohm resistor across the secondaries running the output direct into my system.  With the a balanced input and the transformer in place, the filter doesn't work at all (driven by a SCA A12).  When I wire it unbalanced in without the transformer it works fine.  I read a couple of threads about folks with similar problems, but haven't found any situation like mine.  Anyone have any idea where I could be going wrong?
Thanks for the help,
Craig
