Scenaria
All things LA2a related
« on: November 07, 2004, 10:25:31 AM »
Hey guys,
if anyone has questions in regards to the infamous LA2a, feel free to post your questions here... theres bits and pieces in thread fragments in this forum and I felt it would be better to try and keep the collection in one place :)
this is for ALL la2a questions....
peace!
 :guinness:
fum
« Reply #1 on: November 08, 2004, 11:50:44 PM »
Ok,
For my LA2A's, I'm using Allied part #6K88VG for the power transformer.  Let me run down the wiring  to make sure I've got it clear ( and everyone else has it too =) ):
Primary:
2 Black wires.  Hooked up to the feed from fused, switched mains
Secondaries:
250V
2 Red wires:  hooked up to the 1N4007 diodes ( one each)
Red/Yellow ( center tap of two reds):  Goes to ground?
6.3V
2 Green wires:  Heater supply and to VU Lamp
Green/yellow (center tap of two greens):  Goes to ground?
Grey: shield, goes to ground
Regards
ju
Cainester
« Reply #2 on: November 09, 2004, 01:39:51 PM »
Quote from: "fum"
Ok,
Primary:
Secondaries:
250V
6.3V
Regards
ju
My question too, and in addition to that:
I have looked for links that tell exactly how to hook up the heaters and I have found nothing.  I did find one breakdown of the elements in a tube and noticed that a 12ax7 has 3 connections to the heaters.  Pins 4 and 5 seem to connect to either side of the element, and pin 9 connects to the middle.  So, which pins do I connect the 6.3v to?
The 6aq5's heater is on pins 3,4, so this is a simple 1 to 1 connection, right?
Caine
NewYorkDave
« Reply #3 on: November 09, 2004, 01:41:44 PM »
For a 12AX7 on a 6.3V heater supply, connect 4 and 5 together. Connect one side of the supply to 4&5 and the other to 9.
PRR
« Reply #4 on: November 09, 2004, 04:48:05 PM »
http://www.lynx.bc.ca/~jc/hum.html
At first glance, heaters are just heaters, you just have to give them power.
The 12A?7 family gives you two heaters that can be fed 12V series or 6V parallel.
BUT: the cheapest source of heater power is raw AC from the transformer. And that is equivalent to a 6V 60Hz tone leaking all over the audio. So heater wiring layout is critical. The link above gives good tips and a photo of a bad job.
Most guitar amps put the audio components either very low on the socket or on a tag-strip, and then the best layout is to bring the twisted heater wires straight-up from the socket. Most pro audio tube layout favors setting the heater wiring in first, pressed hard against the chassis, and wiring the audio circuits high. For a row of tubes, you bring the twisted heater wiring out perpendicular to the row, then bend and run parallel to the row, then bend into the next socket, to keep the heater wiring away from the audio.
Good well-twisted well laid-out AC heaters don't hum.... decades of very clean gear was built this way and very little of it resorted to DC heater power. Bad AC heat will hum bad.
cayocosta
« Reply #5 on: November 09, 2004, 05:20:13 PM »
Here's a layout for the La2a heaters:
http://www.vacuumbrain.com/The_Lab/TA/LA2/la2a_heater_layout.jpg
Thanks to CJ for hosting.
Cainester
« Reply #6 on: November 09, 2004, 06:15:34 PM »
Thanks for the great info: Dave, PRR, and Ron,
One more question I have for now is, what is NE2?
Caine
Cainester
« Reply #7 on: November 09, 2004, 06:22:19 PM »
Nevermind,
I found it here:
http://www.vacuumbrain.com/docs/t5.html
bottom of the page...
Great info.
Caine
Scenaria
« Reply #8 on: November 09, 2004, 07:01:00 PM »
NE2 is the neon lamp (used for regulation)
check one of the bags... look for the piece made of glass.. bag is labeled "neon lamp"
Cainester
« Reply #9 on: November 10, 2004, 11:51:10 AM »
I thougt the neon lamp was to light the meter.
Can it be moved over there to perform that function, or should the meter be lit with a separate light?
Scenaria
« Reply #10 on: November 10, 2004, 11:53:52 AM »
nice thought but I dont think its going to be bright enough....
I simply strap a bayonet style leaded socket to the meter bracket and tie it to the power switch..
on the UA version theres a small hole in the front upper right hand side above the meter to hold a lamp bracket... I ommitted this hole as I thought that screw looked tacky...
NewYorkDave
« Reply #11 on: November 10, 2004, 11:54:26 AM »
Keep the neon away from all the audio circuits.
If you want to light your meter, just use a 6V lamp on the heater supply.
CJ
« Reply #12 on: November 10, 2004, 02:49:44 PM »
The bulb is used as a regulator. If you remove it, you have to add some zeners.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
gyraf
« Reply #13 on: November 10, 2004, 03:30:16 PM »
Or do like the re-issues - keep the bulb there for authenthic looks, but use some zeners hidden in heatshrink to do the real job.. :grin:
Jakob E.
Scenaria
« Reply #14 on: November 10, 2004, 03:32:23 PM »
bah
be a real man...
stick with the neon  :razz:
CJ
« Reply #15 on: November 10, 2004, 04:18:52 PM »
I have heard no noise from the neon.
gyraf
« Reply #16 on: November 10, 2004, 04:20:24 PM »
the neon is just there for stabilizing the reference for the meter in GR-mode. Not chritical, to say the least..
Ethan
« Reply #17 on: November 10, 2004, 04:54:38 PM »
I've had 2 zeners burn up and die there, replaced them with neons and no problems since.  Also "upgrading" the 2W resistors in the PS to 4W seems to keep them cool and doing so will probably help them live a longer life.
I am just the Web Geek here.
Ad0lescnts
LA2a problems
« Reply #18 on: November 21, 2004, 05:32:58 PM »
Hi guys,
I'm new here, I usually am on the Homerecording.com bbs and recently found this one, there's a lot of good information here.
Ok so for my question,
I know it's kind of open ended but:
I just got finished with my DIY LA2a using Dave's book, but I have A LOT of buzzing.  Whenever I turn the gain knob I get a bunch of different buzzing noises, and once i pass the 6 o'clock point it sends my meter to the top.  I tried grounding everything all over the place and to the centertap of the 250V wires/AC plug ground.  This just gave me some different buzzing sounds.
Could my problem be that my Hammond transformer doesn't have a centertap for the heaters?  Where should I start on fixing the problem?
Thank you very much,
T
NewYorkDave
« Reply #19 on: November 21, 2004, 06:31:30 PM »
Your heaters are just floating with no reference to ground? If that's the case, that could certainly be part of the problem! Try two 100-ohm 1-watt resistors, one from each "leg" of the heater supply to circuit ground.
Last post August 03, 2004, 06:42:39 AM
by clintrubber
Last post July 20, 2005, 07:08:13 AM
by Samuel Groner
Last post March 29, 2018, 03:06:07 AM
by gyraf
Last post May 01, 2013, 01:10:03 AM
by violindave
