seavote
i'm working with these for the first time. (D-aoc) i did not order a crimping tool .i've heard it is not necessary. the crimp connectors i ordered come in a reel of 100. you need to break 1 off and then trim the sides. i've been crimping the sleeve (tension relief) section first then the wire crimp with a needle nose pliers and then inserting them with the smallest mini screw driver i have. some work out fine others get tossed and i start all over. does any one have any tips?? i'm thinking i'll tin the wire and connector and then solder after the sleeve section is crimped.(insurance?) any suggestions? and yes i know i can go out and buy the tool.
