Re: [BUILd] PM660 / PM670 SCAmp Booster build and tips help thread
« Reply #200 on: June 13, 2014, 06:33:18 AM »
« Reply #201 on: June 12, 2015, 05:32:09 AM »
Hello!
I've just inserted the SCAB and I like it a lot.
My only problem:
How can I have slower attack time? (5ms, 10ms, 30ms)
I'd like to have slower attack even with fast release if it is possible...
gainlab.co.uk
WE MAKE SOUND
duantro
« Reply #202 on: August 25, 2015, 05:27:32 PM »
Hello!
My only problem:
Probably should have posted this in the pm660 thread, but the way I understand it is smaller capacitors in the time constant section = quicker attack times. Experiment here for taste.
ojiban
« Reply #203 on: May 02, 2016, 08:44:34 AM »
Hi diyer's
First of all thanks for this threat...
I'm starding my build of the pm670 with scamp, i hope, soon.
Now is my question: is it smart to build thisone with te germanium resistors? I know it will influence the sound.
Thanks in advance.
Gr ojiban
crisotop
« Reply #204 on: April 18, 2017, 09:58:34 AM »
I've just started working on my PM670 after a long break and having troubles adjusting RV*01 to 0V. I'm using 5k trimmer, might that be a problem? If I'm reading the schematic correctly that shouldn't really be an issue...
thanks in advance,
Christoph
duantro
Re: [BUILd] PM660 / PM670 SCAmp Booster build and tips help thread New
« Reply #205 on: April 22, 2017, 11:03:10 PM »
I'm finally getting around  to try to implement Kingston's Psu mod from the m670 thread, and was wondering if anyone had thoughts on if the scamp board would run happily at 12.6v? I know the ne5534's look to be within range here, not sure about the tip41/42's and thought I'd check if there were any thoughts on implementing this in the m670 mod.
Link for M670 info: https://groupdiy.com/index.php?topic=51478.0
Edit: no response, so I decided to keep the existing +-17v supply in there also.
« Last Edit: May 11, 2017, 02:16:01 PM by duantro »
Last post October 24, 2018, 01:38:19 PM
by latosem
Last post May 25, 2011, 12:42:27 AM
by capnspoony
Last post October 11, 2019, 05:42:16 AM
by mrclunk
Last post August 31, 2020, 01:43:53 PM
by milton99
