Hy Can be used balanced inputs with this board?Out of daw via RME fireface, to resistors board to capi 2-aca-bo stereo out balanced via RME in DAW.thanks in advance
Hy i have heard that signal from resistor board is too weak. After resistor board signal becomes a microphone signal and it is too weak for input in aca board. Is that correct?If so I can put an input transformer in between to increase signal to correct input level for aca?Is that correct.For Chanel's inputs I will use passive summing resistor board van Ian.This is idee rme out to passive summing resistor board out to 2 aca boardThanks in advance
Might help to draw out your connections...I've tied both ACA and BO unbalanced input coms to agnd, chassis pins only for use as cable screen.
If all four units are working fine independently, then it's likely a connection issue. Looks like you might be feeding Bo into ACA?!? (can't tell since picture is cropped).Signal should go ACA 2520---> 2623---> Fader--->2520 booster---->2503
Can I substitute the 33uf PC caps for 47 uf?
Can I turn a Inverting Aca board into 4x fader boosters/output transformer drivers
Started by jsteiger « 1 2 ... 49 50 » Preamplifiers
Started by jsteiger « 1 2 ... 7 8 » Preamplifiers
Started by jsteiger « 1 2 ... 18 19 » Preamplifiers
Started by jsteiger « 1 2 » Mixers/Monitoring Systems
