Etching Own Face plates
sethyrish
Active member
Perth Australia
Hi all. I thought I’d share some recent experiments in etching face plates. After getting quotes of $200AU for Laser and standard engraving were I am, I decided to etch my own aluminium face plates, only to find out that black anodized aluminium can’t be etched. Instead of getting standard aluminium, I thought I’d try brass 1.2mm plate for a real antique look and am very happy with the results. The steps involved are the same as used for etching PCB’s;
1/ Artwork (Adobe Illustrator). 2/ Printed emulsion down (right reading) onto “Press n peel” toner transfer paper. You need to use a laser printer. Then iron onto the metal plate. I had to tape two sheets together to get the length.  You can apparently use photo inkjet paper which would be cheaper but can end up with pin holes which will let the etchant through if not blocked out. 3/ Block out the back of plate and etch with ferric chloride. I added some citric acid which stops any buildup of sediment. This solution is called Edinburg Etch and can be used to etch copper, zinc, mild steel, aluminum and brass. http://www.polymetaal.nl/beguin/mape/edinburgh_etch.htm
4/ Apply some artificial aging and buff high areas. I used copper sulphate for the aging from a swimming pool supply store and some heat from butane torch to get a copper coin type finish. All up it was about $50AU for 3U of rack.  The iron-on paper did require a fair bit of experimentation to get the temperature and pressure correct. You are basically melting the black toner and smudging it onto your plate. The toner repels the etchant.
I like it!  It gives a pretty cool Steampunk look.  I'm going to use your idea for a nixie clock enclosure I've been planning.
Excellent!  Very Jules Verne.  I was just thinking about the same thing after browsing the DIY Stompbox forum and seeing some great designs there.  I'm amazed by the level of detail you achieved on the etch.  About how long was the etching process itself?
A P
Now isn't that stunning :eek: This is why the forum is so appealing. Lots and lots of creative work on display to watch and learn  ;)
edit:
And one can even etch those "predrills" for holes making the rest of process ever easier!
very stylish indeed!!!! and thanx for the link on making those etching solutions, good reading! I've etched some stompboxes with the toner transfer method and some ferric chloride but i've never been able to etch that deep and clear.
greets,
Thomas
cool, i hope we'll be seeing lots of this stuff.
looks great!
thanks for the link ;D
By how much does the enchant seep under the the toner?
Do u have to allow a bit of an offset on your graphics designs to allow for this?
How long did it take to etch that plate?, it looks pretty deep.
Chemical mordants will etch most materials isotropically.  The amount of undercut (x-y direction) will be roughly equal to the etch depth (z-direction).  Mass transport issues will tend to give z-etches a slight positive bias though.
WHOAA!!
That's all I can say, I mean it looks like a front panel that a 17th century pirate designer would make if you asked him to make something that he thinks will be made 300 years ahead of his time.
Fantastic! I love it!
Good stuff. Welldone. I have been working with etching for over twenty years and I must say that is a really great look and finish. You have certainly mastered the technique of aging. Excellent.
