need pointer on using a vacum tube for tone control and Q control
skal1
Birmingham,uk
Hi
i do not have a good understanding of the tube thing but i would like some help with designing a simple tone control and Q control from a tube , i think the filter section can be used out of pultec  but i have no idea how to too graph the tube into each section of the filter..
any help would be nice
regards
skal1
yes that should work , i found this schematic but i can not make head or tail of it , here is the link
http://i51.photobucket.com/albums/f392/skal34/tonecontrol-1.jpg
i think this should work but their might be other issues / impedance .
skal1
yes i know , could i graph the L C NETWORK out of the pultec in their ,would that work ?
I was also looking at the kh ue-100 but can not read german but that looks like a good place to start as well.
skal1
skal1?
I am curious what became of the eq project you inquired about a few months back.
Orban(?) and tube eq???
I recall you wanted to use valve based op-amps...have advances been made?
cheers
Because that's not the whole thing.
Read the entire chapter.
@PRR , i have read the for mentioned chapter and have found their is not one single way to implement this circuit so i think i will get myself a tube proto board and start from their , i am not a theory persons i am a hands on person so i will have to go this way .
I do not want it to be a strap on tube thing like the pultec.
I think i will need a triode tube for this ,one side to boast the other to attenuate and then placing  the filter section for each side in  series or parallel
{ just guessing now  } with the corresponding sides of the triode.
so in the next coming day i shall come up with a circuit and then you can laugh.....at my neebie ness
skal1
