I just finished my 9th preamp and the first vp26 stepped gain. Everything seems works fine but I have a question.
Since I have no way to check the sound with fancy machines (of course I checked the testing point first), I just load the pre with 2 mics (matching pair), and do a little recording. Nothing weird so far.
Right now during this quarantine I have available just another vp26 variable gain. After testing I noticed a little difference between the two.
The stepped one has a tiny bit more output gain at the same level (thing I 've already noticed between other Vp stepped gain models) but the strange thing is that always the stepped one has more proximity. the tone is exactly the same (at least at my ears). Is not even presence, is more like, when you move the mic far from the source, is more noticeable on the variable gain then the stepped gain. And getting a sound from a close source seems the stepped has more presences.
I swiped the mics and re did it, and the result still the same, so they are a real matching pair
Now, those thing are not really bothering me since both of them sounds awesome, I'm just looking for tips and confirm those difference if somebody else had the same experiences.
although I did apply a little modification on the build, maybe you can give me a tip also on this one. For some reason (I'm not going to explain here since I already wrote too much), I applied pins to the output transformer cable. I checked before installing the ohm of the cable with and without pin and saw that was the same, so I decided to go for it. Obviously the result is that the preamp works, not sure if the pins are making actually difference here (pic is attached)
My question is: did anybody noticed those differences like me between those 2 preamp?
