you could use mnats (or for overkill Fabio's) dual power supply and replace the trim pots with a potentiometer to adjust the voltage to your needs. better to have a pot which is spec'd higher wattage for longevity, but DOAs don't draw that much current.
you could also modify an adjustable +/- V-regulator PSUs such as Peter C's.
put it in a box and you've got a bench/lab dual supply. that's what i did. won't do very high current (dependent on your current rating of your PSU components), but you should be able to do most projects with it just fine.
regards,
grant
