Hi there,
A bit late, but here's the writeup of what I did:
First I pulled out the transformer and attempted to remove the piece of paper in the bass chamber. I was unable to pull it out with tweezers, but I got a better look of it. It appears to be some kind of spongy material with self-adhesive backing. It must have been glued to the back of the chamber originally for taming the resonance. It's probably not too good to have it detached though. Problem is, I think I'll need a hammer to open the chamber up, and I really hope I won't break it. Maybe I should get a spare chamber instead, mine was damaged already anyway...
This is the best picture I managed to take through the little hole at the bottom of the bass chamber:
For reference as I have not seen pics elsewhere, this is how the transformer looks like:
And this is how the front of the capsule looks on mine:
Next I took apart the shockmount and removed the capsule. Note: somehow I got lucky the first time and failed to notice how annoying it can be to put the shockmount back together. Especially that there is a hungry magnet ready to swallow the screws through the went holes on the capsule's side, into tweezerland. But I'm getting ahead of myself
The unsoldering and re-soldering of the tiny wire was actually easier than I tought it would be. I did practice with a similar gauge wire beforehand though. The plastic tie-wrap is definitely handy for moving the wire in and out of the solder.
I took off the capsule with grille, brass ring, paper shims & all. The coil gap appeared to be clean but I used 1000 grade sandpaper really gently to make sure it really is, and blew it out with compressed air afterwards. I made sure I can see the brass shining at the bottom of the gap and that there is no oxide stuck in there.
Here's some pics of the mic as disassembled:
I used a thin screwdriver for separating the shims from the brass. This is the part most likely to increase your grey hair count. Be *really* careful with that screwdriver / scalpel / whatever!
Once I got the brass and the membrane to separate, I noticed that the grille comes out as well -- it's held in by the edges of the same six screws that hold the diaphragm assembly in place. In fact, the grille was probably the source of the misterious rattle I heard earlier. I have already loosened the screws a bit, and it probably caused the grille to come loose. Either that or it had something under it that was rattling against the diaphragm. I'll never know, but the noise is gone. This is what the other side of the membrane looks like. There appear to be some fine oxide particles embedded, but nothing serious. Whatever's stuck in the membrane ist there to stay though, I will not risk trying to remove it:
So I tried to make sure that the gap is clear, the coil is clear, and the membrane is as clean as possible. I then reassembled everything. I did not have the holders for the solder joint. Whoever last repaired the mic just added some chewing gum to hold it in place. I replaced this with some blu-tac which may not last as as long but is much less disgusting
I tried the sine wave test with no rattle but no improvement either. I then tested the mic on the bass cab this morning and again I did not notice any improvement. I will try to realign the capsule but I'm not too confident that it would help. In any case I'll use the opportunity to mike it up and record the sine sweep, to make sure I'm not missing anything. Any suggestions on what to try next?
Vik
UPDATE: I forgot to add that larger versions of each pic are available at the same place here:
http://www.avatarzenekar.hu/files/d12/
