ENS Audio
Next DIY project is going to be a 2-ch 1176 so if anyone has the layout file(s) for the front panel, that would be awesome! :D
signalflow
Re: Does anyone have a custom front panel layout for the 1176?
« Reply #1 on: June 06, 2009, 08:16:40 PM »
Found this online it's not a FPD file but it's better than nothing.
http://i41.tinypic.com/34t7b10.jpg
-Casey
The shortest distance between two places is a nap.
KMB-AUDIO
« Reply #2 on: June 08, 2009, 03:15:30 PM »
I have Front Panel express design that I styled after the distressor....I also have another one that is my own design. I'll post them tongiht.
Call me Matthew.
KMB-AUDIO
« Reply #3 on: June 09, 2009, 11:40:45 AM »
Here it is..the other one I had was a single.
I am going to use this design for a dual that I'm building with the mnats blue stripe boards.
Change the .txt to .fpd
Call me Matthew.
ENS Audio
« Reply #4 on: June 10, 2009, 01:48:12 PM »
Thank you!! :D
phatmateo
« Reply #5 on: June 10, 2009, 06:11:49 PM »
hmm...it wont let me rename it to an .fpd file.   Am I doing something wrong?
geetar_king
« Reply #6 on: June 10, 2009, 06:29:01 PM »
Maybe you don't have the "view file extensions" option enabled. Could you see the .txt in the file name?  If not, then open the folder the file is in, and go to the Tools>Folder Options>"View" tab> and uncheck the one that says 'Hide extensions for known file types'
After that you should be able to change the .txt to .fpd
Might be a bit different depending on your computer, but maybe thas the problem??
phatmateo
« Reply #7 on: June 10, 2009, 06:35:02 PM »
thanks for the info!  That fixed it, but now it says the file is corrupt when I open it in FPD
smallbutfine
« Reply #8 on: June 10, 2009, 06:40:18 PM »
Wouldn't this thread fit better into the lab? ???
"In the past we suffered from crimes, today we suffer from laws."
Tacitus
www.audiomh.de
geetar_king
« Reply #9 on: June 11, 2009, 07:50:18 PM »
I tried the file too, and it's corrupt
Last post June 19, 2005, 02:18:36 PM
by TomWaterman
Last post October 29, 2006, 12:27:43 PM
by Vikki
Last post September 09, 2009, 07:32:26 PM
by Ringwraith
Last post February 09, 2010, 09:07:02 PM
by Gold
