I am having a hum issue (unknown if it is a ground hum) when the output is turned to 2 or 3 o'clock the hum is not audible, but anything over is a problem. is this normal for G1176's? The unit does not have an input transformer, but does this make a difference? the circutry has an input transformer, but the circut is open. I also can not locat a 4M7 trim pot for the release, ( I used 2x 2M daisy chain ) so is there anything that i can use to substitute? if not, what other options are there?
Thank!!!!
Thank!!!!
