Standard version (+/- 3,6,9,12,15 dB)
http://audioxxx.googlepages.com/EQ_169_STD_schematic.pdf
Mastering version (+/- 1,2,3,6,15 dB)
http://audioxxx.googlepages.com/EQ_169_MAS_schematic.pdf
Shared documents (for both standard & mastering version)
http://audioxxx.googlepages.com/EQ_169_STD_layout_designations.pdf
http://audioxxx.googlepages.com/EQ_169_STD_copper_mirror.pdf
http://audioxxx.googlepages.com/EQ_169_STD_frq_selection_lo_filter.pdf
http://audioxxx.googlepages.com/EQ_169_STD_frq_selection_hi_filter.pdf
http://audioxxx.googlepages.com/EQ_169_STD_frq_selection_table.pdf
http://audioxxx.googlepages.com/EQ_169_dimensions.pdf
Earlier this year I built a mastering eq for a friend of mine. It is based on Studer 169 mixer channel which has an equalizer that I like a lot (and there are many others sharing my opinion). The feedback that I got was very very positive. So I decided to draw a PCB for it to make it available to all of you (the prototype was a ratnest/veroboard version).
Several changes has been made to the original circuit. Potentiometers are replaced with rotary switches (for accurary). Original fixed frequency is replaced with 5 selectable frequencies.
The eq section contains only one op-amp. It can be used in unbalanced mode (input and output section not assembled) if extremely pure signal path is required. Debalancing and balancing amplifiers are however included in the pcb. If all components are assembled, it provides balanced input and output.
The eq op-amp is classic NE5534 but there are huge amount of pin compatible alternatives available. So you can replace it with better (or at least more expensive) if you want.
The PCB is single sided and suitable for home etching (large pads and thick traces). The board size is 194x38mm. So it fits easily in 1U rack case as well as in standard 40mm mixing console channel module.
Switches are Lorlin series CK. They are available everywhere and there are number of equivalent types from other manufacturers too. Types used are 1x12 shorting and 2x6 shorting. Non-shorting switches can be used but some additional switching noise is likely.
http://www.lorlinelectronics.com/pdf/CK.pdf
I have made a lot of work to make this unit tidy looking and easy to assemble (all switches are on PCB). Please don't wire the switches. First, it looks horrible. Second, it increases noise pickup and long wires can cause oscillation (it is unlikely but possible).
As usual, I don't sell boards, components or anything related to this project.
Boards are available from Gustav:
http://www.groupdiy.com/index.php?topic=10776.0
My other projects:
Neumann W492 EQ
http://www.groupdiy.com/index.php?topic=28332.0
Neumann OA10 discrete op-amp
http://www.groupdiy.com/index.php?topic=34105.0
Balanced 12 input summing amplifier
http://www.groupdiy.com/index.php?topic=29082.0
Balancing/unbalancing amplifier
http://www.groupdiy.com/index.php?topic=29333.0
