Do you have the resistor values for the mastering version?
sorry for the newbie question, but is it just a two band(hi and lo) shelf eq?
what goes between C and D? is it for a bypass switch?
Gerber files are also available if someone wants to manufacture boards "in larger scale". Gustav?
Is the second NE5532 (or other half) just used to ballance the signal. Can I leave that out and ballance with a 1:1 output tranny?Thanks.
For instance, I I wanted an 8,8K would I two 11nf or two 22nf.Thanks,
should the two caps split the nf value
Does anyone have panel cutout dimensions for these?How far apart are the rotaries if mounted to the pcb?And how much room from the outer rotaries to the edge of the pcb?
Started by q2audio The Lab
Started by Paul Fury 161 The Lab
Started by manarm The Lab
Started by audiox « 1 2 3 » The Lab
