After several blind alleys with working on the power supply for this *** Behringer POS console, I think I am finally understanding what is happening. I'm hoping that you all can confirm or deny my logic.
Here's the schemo. I'll go through the components one by one to say what I understand they are doing, and you guys can tell me where my assumptions are wrong. ;-)
T, the transformer, is providing ~52V AC. The "listed" voltage on the PCB is 48V, but my measurement is consistently about 52V.
F, the fuse, is rated at 500 mA. Theoretically, it protects the rest of the components from excessive current.
D11, D16, D21, D30 are diodes forming a full wave rectifier. They make the 52 V AC into ~50 V DC, with ripple. The reduction in voltage is due to the voltage drops across each pair of diodes as they become the active pair.
C22 removes the ripple from the 50 V DC, making it 70.5 V. This 70.5 V is the peak voltage of the 50 V(rms) supply.
C11 - I believe this is the bypass cap for the voltage regulator
LM317HV - this is a high voltage version of the LM317 voltage regulator, with output rating up to 60V. Its job is to keep Vout at some portion of Vin, based on the development of 1.25V between the Vout terminal and Adj. The level of Vout therefore depends on the ratio between R2 (240) and R1 (9.1k) (It's unfortunate that the component numbers from the PCB are exactly opposite how I usually look at voltage dividers, which have R1 on the top and R2 on the bottom). As long as Vin is below 48V, (R1 / (R1+R2)) gives us numbers below 1.25V. When Vin reaches 48V, Adj reaches 1.25V and keeps it there even as Vin continues to rise.
C1 - bypass cap for the adjustment terminal
D6 - protects the LM317 from discharge of C1
R2, R1 - form the voltage divider that establishes the adjustment voltage between Vout and Adj.
C15 - bypass cap for the output
D7 - protects LM317 from negative voltages that might end up on the +48V bus
C16 and R3 - filtering for +48 buss output
D1 - this is the tricky bit. What does it do? In the application notes from National, they show a similar configuration, but with a diode in place of the zener. Its function is listed as protecting the LM317 from the discharge of C1. How is it suppposed to do that when it doesn't even turn on until Vout is 33 V higher than V in, i.e. 81 VDC!!!
I've been struggling with this supply for a while now, and it's just bugging me so much that I can't really just let go of it. I think I may have bought the wrong size of 33V zeners, because when I power up the unit, everything is fine if there's no load at all, but the moment there's any load at all (like connecting just the cable, not the console, the breaker blows up.
I see some options:
- get a zener rated at 5W
- use a 1N4001 diode in place of the zener
- remove and leave out C15 and its protective diode D1
Thanks for your help!
