It sais on Hairballs little push button 1176 manual to check the specs if it can handle it, but his push button switches did not come with spec sheets. His manual sais to use Neutral from the IEC to wire it to the 1176 push buttons if voltage is an issue. Is this safe to do, that's 240 volts going thru those push buttons that are directly in contact with the user pretty much and sparks could fly?
Would this cause any form of issues having the power direct from the IEC going thru the Push Buttons, like grounding, noise, magnetic field, whatever?
How about adding a snubber, I read this up on Drips La2a manual? Is this possible with the 1176?
