If you are considering installing 'vintage' caps in an LA-2a, be warned.
I think that the vast majority of techs who've been around a bit have had some experience of the output DC-blocking capacitors failing, and when they go, they take the (now ÜBER-expensive) output transformers with them.
Installing 'vintage' caps in an LA-2a? -Personally I think it's a fool's goal. -Any 'gain' is utterly outweighed by the horriffic risk, in my experience. Newer caps are more reliable, and unless you have a capacitance tester which tests caps AT THEIR RATED VOLTAGE, then yes, absolutely. Your hand-held multimeter can read a good value, while that same cap can still be a mini-grenade ready to pop as soon as it gets hit with a hundred volts or two.
Caps can read correct capacitance on any number of test meters, and the dielectric can fail when high voltage is applied. -Old electrolytics are the WORST for doing this, and in any case, there are LOTS of different ways that a cap can "go bad". -High ESR can lead to excessive heat, which can in turn either dry out the cap once it's in use, resulting in low capacitance once it's been in use for a while, or occasionally dielectic failure or leakage. High leakage again frequently leads to temperature rise etc.
Summary: -In an LA-2a, NEVER use "vintage" capacitors. -There's a thread over on PSW where this exact thing was discussed, and a couple of techs (who between have repaired more LA-2a's than I've possibly even seen) chimed in to share their collective opinion as to the foolishness of such an endeavour.
Don't do it. -Non-elects are much less risky, but electrolytics... you'd have to be mad. -For the PSU especially, modern caps are *SO* much better in every respect.
-But if you must persist with your investigations, may I respectfully offer the following advice:
NEVER APPLY POWER with the case open, unless you are wearing a FULL-FACE MASK.
-And no, I'm not kidding.
Keith
