Re: Neumann OA10 discrete op-amp (in API 2520 etc. format)
« Reply #20 on: January 24, 2010, 01:54:26 PM »
I was actually talking to audiox...but I always test ;)
I guess you received the Gerber files... Good luck for experimenting, please report your findings here.
As I told you are free to offer boards and kits as long as the price is fair. (Naturally that permission applies to my part of the design only.)
dmp
« Reply #21 on: June 26, 2010, 01:06:39 PM »
Does anybody know / have a working link to these docs from the DOA meta?
Neumann OA10
www.silentarts.de/lab/studiotechnik/neumann/OA10_Schematic.pdf
Neumann OA10 -- The schematic. Did you know they made their own opamps?
www.silentarts.de/lab/studiotechnik/neumann/OA10_Data.pdf
Neumann OA10 Data
[silent:arts]
« Reply #22 on: June 26, 2010, 01:43:46 PM »
should be mirrored at www.kubarth.com
dmp
« Reply #23 on: June 26, 2010, 02:33:50 PM »
Thanks! Found both docs on this page:
http://audio.kubarth.com/rundfunk/index.cgi
BTW, I requested samples of these Millmax pins to try in the OA10 holes:
3145-2-00-15-00-00-08-0
strangeandbouncy
« Reply #24 on: July 16, 2010, 07:39:49 PM »
   I am  having a problem trying to run down the BC182BP. I can't even find it on a datasheet. I can only find BC182A, B or C. Can I use BC182B instead? How exactly does the BP version differ from any others? Is there a suitable sub?
     Kindest regards,
     ANdyP
. . . . RUH ROH . . . . .
« Reply #25 on: July 17, 2010, 11:19:28 AM »
Ignore the last letter.
strangeandbouncy
« Reply #26 on: July 17, 2010, 11:22:59 AM »
Hi Audiox,
    thanks!
]     Kindest regards,
    ANdyP
strangeandbouncy
« Reply #27 on: July 20, 2010, 05:50:04 PM »
    anyone got one of these working yet? I am perilously close(just awaiting some silicon . . .) ANy suggestions for pins? my usual just fall through the holes! Contemplating single core  stripped mains cable to save money . . .
   Checking the tech data for the 0A10, I am intrigued to see the slewrate increasing with gain . . .
     Kindest regards,
       ANdyP
RedNoise
« Reply #28 on: July 20, 2010, 06:57:03 PM »
1N4007 legs  make quite perfects pins for tho kinda DOA...
If your neighbour is hunger : don't give him fish , teach him how to fish ...
if you don't like it don't buy it ;-)  [Wolker Texas Ranger] ( ;-) )
strangeandbouncy
« Reply #29 on: July 20, 2010, 06:58:52 PM »
RedNoise,
   . . . . my kinda DIY!
     Kindest regards,
    ANdyP
strangeandbouncy
« Reply #30 on: July 24, 2010, 12:09:00 PM »
   OA10 equals SMOKE . . . . . .  ::)
   perhaps there are different versions of the transistors with different pinouts(?)
     v annoyed . . .
  Kindest regards,
    ANdyP
3nity
« Reply #31 on: July 24, 2010, 01:00:14 PM »
thats frustrating...but what went on smoke?
On some attempts on building stuff....mostly resistors go on smoke....
Last time it happened to me was on a FetBlock by [email protected]
What went wrong were 10R reistors...http://skipwave.net/images/bigfetbloak_v2.pdf
Life is a path, death the destination.
strangeandbouncy
« Reply #32 on: July 24, 2010, 03:19:09 PM »
transistor(s)
« Reply #33 on: July 24, 2010, 10:57:04 PM »
Check your 212s... if you didn't use motorolas, flip them around.
strangeandbouncy
« Reply #34 on: July 25, 2010, 05:09:25 AM »
HI,
       Thanks, Mitsos
        Kindest regards,
          ANdyP
« Reply #35 on: July 25, 2010, 07:04:15 AM »
In my layout:
BC212 and BC182:
C B E
BC327 and BC337:
E B C
From left to right (see the following picture)
http://rocky.digikey.com/weblib/Micrel/Web%20photos/576-TO-92-3%20(bent%20legs).jpg
strangeandbouncy
« Reply #36 on: July 26, 2010, 05:37:37 AM »
Thanks Guys,\
   this may seem a sily question, but how do i know if my tranasistors are Motorola? There doesn't seem to be any brand marking on mine
   Kindest regards,
      ANdyP
strangeandbouncy
« Reply #37 on: July 26, 2010, 10:08:47 AM »
Hi just tried my transistors in a multimeter. I am new to this,
   but I get a reading for HFE only with correct orientation, yes?
      I think both my bc327-25 and bc337-25 are C B E left to right with flat side towards me, like Audiox's picture
  I haven't tried to swap 'em out yet, and perhaps I'd be quicker to build another one!
    Kindest regards,
      ANdyP
« Reply #38 on: July 26, 2010, 11:12:17 AM »
yes you should only get a reading if it's in the right way.
Much easier to tell orientation in a multimeter though! I only mentioned motorola 212s because as I was having fun with those datasheet pages that come up in google, it was the only one of the 3 brands (fairchild and onsemi are the others) that matched the pinout.  I think the 182's were all the same, didn't check the other two. Figured you might have the invoice. Anyway, it's much easier to tell orientation on the multimeter!
It's not too hard to remove these small transistors with a soldersucker. Just be careful not to heat too long and lift the pads!
good luck!
strangeandbouncy
« Reply #39 on: July 26, 2010, 11:27:28 AM »
   Thanks, Mitsos!
   Kindest regards,
      ANdyP
Last post December 17, 2004, 09:56:14 AM
by dmlandrum
Last post September 10, 2007, 09:57:12 AM
by audiox
Last post August 13, 2012, 06:17:09 AM
by shredup
Last post September 24, 2012, 03:58:44 AM
by ppa
