On a standard USA power cord, the small prong is the hot (black) , the larger prong is neutral (white), and the round prong is ground(green). Hook your power cord hot to the tip of the fuse, hook the sleeve of the fuse to 1 side of the SPST power switch, hook the other side of the switch up to 1 primary lead of your power transformer, the other power transformer primary lead goes back to the white wire. If you're using a DPST switch, you can switch the neutral if you like. The green obviously goes to the chassis.
-Richard
