230 volt transformer for a Roland Dimension D
API
Sweden
Hi.
I own and original Dimension D 19" rack chorus.
It is 120 volts only though, I opened it up and it did not seem like there were taps for 240 volts.
Does anyone know where to source a transformer for this?
Or maybe there is someone in the US with a 240v version that wants to swap transformers??
A long shot but you never know  ;)
Here is a pic of the transformer in mine.
API
Thanks for the docs, I did not have those.
I guess I will need to find a 230 to 48 v ac transformer, that should do it.
API
Quote: "I guess I will need to find a 230 to 48 v ac transformer, that should do it."
I guess not. From the posted service info, the schematic shows +/- 20 VDC after rectification, and +/- 14 VDC after regulation.
You need a 2 X 15 V transformer. On the first page of the same document it says; Power consumption : 8W. That is the VA rating you need.
Axel
