blue_thunder
Member
- Joined
- Jun 11, 2009
- Messages
- 11
I've got a JCM 900 head that has developed a crackling sound and drop outs when I adjust the master volume or reverb knobs. It is happening on both channels, but all of the other knobs are quiet as can be. I've tried spraying contact cleaner into the pots and working them back and forth, but it didn't seem to help any. I ran a cable from the effects send to another amp and there was no crackling or drop outs when I adjusted any of the knobs (of course this bypassed the master volume & reverb so those knobs did absolutely nothing). If I run the cable from one of the preamp outs, the noise is there when I turn the master controls. I tried swapping the tubes, but the noise was still there. I rewetted the solder joints on the knobs, but that didn't help either. I cleaned the jacks & pententiometer for the effects loop, but the noise is still there. I looked for loose solder joints, but found none. Can anyone tell me what else could be causing this problem?
