High current audio op-amp (is there any replacement for the MC33076)
audiox
I just noticed that good old MC33076 op-amp has been discontinued. I will really miss it.
It was cheap. It provided relatively good audio performance (good enough for most applications). But most importantly it could give up to 250 mA output current.
Most often I used this chip to change a standard balanced output into high current one (needed for example to drive long cables or difficult loads). I just changed the original NE5532 to MC33076. No modifications to the circuit required.
Is there anything similar available?
