Reset combination for TC fianlizer
when you say it doesn't boot up do you mean it turns on, but doesn't load the firmware? or it just doesn't turn on at all?
I've had a unit that wouldn't recognize the firmware and you had to load firmware back into the unit from the card slot... replaced the battery and all it good now.
good luck
Self test menu
  1. To enter the Selftest menu press and hold "BYPASS" button.
  2. Power on the unit and scroll to "RUN TEST PROGRAM".
  3. Follow the instructions on the screen..
Resetting the unit:
  1. Power up the unit while pressing and hold the "HELP" button.
  2. Scroll to reset system, please make sure to backup all presets!
  3. Confirm by pressing "OK".
