Rob Flinn
Reset combination for TC fianlizer
« on: June 29, 2009, 08:30:06 AM »
Does anyone know how to reset the TC finalizer.  A friend has one of these & it doesn't boot up, has anyone experienced this, or know the solution ?
regards Rob
strangeandbouncy
Re: Reset combination for TC fianlizer
« Reply #1 on: June 29, 2009, 09:36:45 AM »
When mine did this, it was the power supply iirc . . . .
. . . . RUH ROH . . . . .
Rob Flinn
« Reply #2 on: June 29, 2009, 11:29:06 AM »
Thanks Andy, I'll see if I can find our whether there are some symptoms or whether it is just completely dead !
regards Rob
Sarcastic Sound
« Reply #3 on: June 29, 2009, 03:59:09 PM »
when you say it doesn't boot up do you mean it turns on, but doesn't load the firmware? or it just doesn't turn on at all?
I've had a unit that wouldn't recognize the firmware and you had to load firmware back into the unit from the card slot... replaced the battery and all it good now.
good luck
drpat
Re: Reset combination for TC fianlizer New
« Reply #4 on: June 29, 2009, 04:29:12 PM »
« Last Edit: September 18, 2010, 07:37:45 AM by drpat »
I use the LA2a on very hot signals like lead vocal.
Rob Flinn
« Reply #5 on: June 29, 2009, 04:44:14 PM »
OK thanks for the tips guys.
regards Rob
kooma
« Reply #6 on: June 30, 2009, 02:04:20 AM »
Self test menu
   1. To enter the Selftest menu press and hold "BYPASS" button.
   2. Power on the unit and scroll to "RUN TEST PROGRAM".
   3. Follow the instructions on the screen..
Resetting the unit:
   1. Power up the unit while pressing and hold the "HELP" button.
   2. Scroll to reset system, please make sure to backup all presets!
   3. Confirm by pressing "OK".
Rob Flinn
« Reply #7 on: June 30, 2009, 05:18:21 AM »
Thanks Kooma
The actual problem is as follows:
"When it's turned on the display lights up but not showing and info, just a blank green screen. Pressing buttons does nothing at all."
regards Rob
Last post May 16, 2010, 06:37:20 AM
by Steve Jones
Last post January 27, 2012, 11:35:18 AM
by JohnRoberts
Last post September 30, 2012, 12:10:33 PM
by leadbreath
Last post February 18, 2013, 04:11:29 PM
by bockaudio
