Gus said:What new microphone?
It's been done a number of times.e.oelberg said:In the new mic by Oliver Archut he uses both sides of a tube ( I guess it's something like a ecc81) parallel, I haven't seen that before,
are their other similar circuits ? Did anybody try that ?
nicholas
abbey road d enfer said:It's been done a number of times.e.oelberg said:In the new mic by Oliver Archut he uses both sides of a tube ( I guess it's something like a ecc81) parallel, I haven't seen that before,
nicholas
Three advantages:
The output impedance is halved
The noise factor is 3dB lower
It offers some redundancy if one half of the tube goes down
PRR said:What strikes my eye is the clever remote pattern control, eliminating a grid capacitor.
PRR said:That's all trivial. What strikes my eye is the clever remote pattern control, eliminating a grid capacitor.
ioaudio said:nicholas, the rise of noise in your mic is due the insluation of standard relais. i see that o.a. used standard relais too, but maybe he modded them for high Z use? special (costly) highZ reedrelais can be found from a german manufacturer.
-max
PRR said:> any disadvantages to this way of doing things? Engineering always seems to be a game of compromises so I'm wondering what gave in this instance? (if anything).
In any rational world, two triodes cost more than one.
However, there are very few small single triodes in current production; boat-loads of twin triodes.
In a bigger box, you would find another use for the "excess" triode. Tremolo. Insert buffer. Or another input, with knob and jacks, which looks more impressive (higher price) on the showroom floor.
But not much you can do in a microphone. Gain stage - cathode follower actually adds more trouble than it solves.
And if this thing sells for much more than $99 (it surely does), the cost of a twin-triode is nearly negligible.
And in this irrational world, surely smaller than any assured-supply small single triode or low-noise pentode (which could be triode-strapped).
In this application you want to balance several conflicts:
1) low-low grid current
2) high plate current for low voltage noise and high drive
3) low heat near capsule
4) cost versus value
#2 is also related to cathode area. At the same current (heat), a larger cathode has lower current density and lower voltage noise. We would like a single triode with an over-large cathode. But this world is not rational. Anyway cathode cost is a large part of tube cost. And most uses do not need over-generous cathode. Using two cathodes as one "forces you" to pay for an extra grid and an extra plate, but translates to a broad-market twin-triode instead of a narrow-market fat-cathode single triode. So it is cheaper. Even if money is low-priority, supply and spares are always a concern.
The ~~5V bias means grid current will be low. And splitting the same plate current into two grid streams may not mean more total grid current. And at 5V, in practice grid current on modern tubes will be dominated by gas, not the stray grid current of a "perfect" tube. Surely the tubes are "selected". If this is a $99 mike, the Banjo Mart customer "selects" by taking back the worst hissers for exchange. If this is a $9,999 mike, there is a strict spec for the tube factory and additional burn-in and testing in the mike assembly process.
