Biasrocks
Re: 1176 Plosives: looking for Rev A schematic or high res internal shots
« Reply #60 on: January 17, 2010, 05:30:48 PM »
I am aware that mine is a rev B, but Are you sure that the Rev B didn't have the dual FET? My schemo shows it, and  q4 is socketed, as are the other FETs....
Hi Chuck
I'm not sure which schematic you're referencing.
REV B as noted in the 1176 docs from the JBL site shows this note for 1176 "B".
"Two transistor input amplifier"
The REV B schematic shows this as well.
Mark
« Last Edit: January 17, 2010, 07:09:43 PM by Biasrocks »
http://SharktankPro.com
"I'd rather use an SPX90 than a UA plugin....." Joe Barresi
la-2a
« Reply #61 on: January 18, 2010, 11:21:45 AM »
Hi, I uploaded the scans.  1176_125 is serial 125,  1176_293 serial 293.
here the link : http://yfrog.com/dy11761251jx
Hope I could help and all is O.K. Pictures will follow soon when I am back in the studio :)
I was just thinking about recapping the units. What would you guys do.?? Keep it original.??
cheers
« Last Edit: January 18, 2010, 11:30:34 AM by la-2a »
Biasrocks
« Reply #62 on: January 18, 2010, 11:36:09 AM »
cheers
Thanks for those!
You should definitely recap it, you need only do the electrolytics and tantalum capacitors.
Everything else, leave as is.
Mark
la-2a
« Reply #63 on: January 18, 2010, 11:47:36 AM »
Hi, here the pictures of one of the units .Serial 293 labeled B-Version. The other one is
is older and has no LN modification. It should be the real A-Version.
la-2a
« Reply #64 on: January 18, 2010, 11:48:56 AM »
another one SN:293 -B
« Last Edit: January 18, 2010, 12:05:24 PM by la-2a »
la-2a
« Reply #65 on: January 18, 2010, 11:50:24 AM »
ONCE MORE :)
barclaycon
« Reply #66 on: January 18, 2010, 12:53:19 PM »
la-2a
Thanks for the schematic scans - some of the clearest I've seen.
When you get chance can you do some pictures of your 125 unit, like the ones you've done for the 293.
They would be extremely useful.
Thanks again.
ChrioN
« Reply #67 on: January 19, 2010, 09:41:56 AM »
This thread confuses me  ;D
I hope someone makes all the hard work for the rest of us.  :D
"All PCB traces are curved to emulate the electrical response of point-to-point wiring" -Drip
la-2a
« Reply #68 on: January 19, 2010, 05:03:12 PM »
Hi here  we go, here are the pictures of my Bluestripe Serial Nr. 142 ....sorry not 125 like It was written on the schematics , but not that far away: And it is  an original REV A.! :) .
I  will make some postings now here because of better resolution.
cheers
la-2a
« Reply #69 on: January 19, 2010, 05:04:23 PM »
next one
la-2a
« Reply #70 on: January 19, 2010, 05:05:55 PM »
the pushbottons
la-2a
« Reply #71 on: January 19, 2010, 05:08:16 PM »
and the serial..........
I hope I could help again ........this forum gave me so much.....
thank you .
Rob Flinn
« Reply #72 on: January 19, 2010, 06:05:30 PM »
LA2a thanks for that..   You're pics are very useful.
regards Rob
Rob Flinn
« Reply #73 on: January 19, 2010, 06:25:11 PM »
From what I can see so far it seems to have all the resistor values of the Rev "A" diagram.
By the way most of the blue electrolytics on the board look a little past their sell by date.  Have you tried testing them with an esr meter ?
« Last Edit: January 19, 2010, 06:27:56 PM by Rob Flinn »
regards Rob
la-2a
« Reply #74 on: January 19, 2010, 07:25:13 PM »
You will not believe it. I checked them some time ago with my Tenma LCR Meter and the values were inside the tolerance.
Compared to my REV A Clone it has not that open end, but I love them how they are.
But your´re right. I got to recap the units soon  ;). I just don´t know where to buy that big sized
PSU Caps  :D
cheers
Rob Flinn
« Reply #75 on: January 19, 2010, 07:35:34 PM »
PSU Caps  :D
cheers
D
Does your Tenma LCR meter test ESR (equivelent series resistance)?  That is really the property that is important.  Many caps can spec near to the correct capacitance value but their ESR is out of spec.  TMostly I notice that the smaller values are most problematic.  You may find that the larger PSU caps are ok.
Also how did you populate you blue stripe clone, which diagram did you use ?? DOes it sound like your originals ??
regards Rob
la-2a
« Reply #76 on: January 19, 2010, 08:30:02 PM »
[/quote]
[/quote]
I used  the complete Hairball Kit inclusive  Altran C-3837-1 and EA-5002 transformers, mnats  rev A board, the orange drop 1mf caps.
Resistor values pushbutton now: 180R,470,470,1.5K ,10M, 56K, 56K, 68K. (130K changed to 68K)
R46 = 22K.
The reason why I went to this threat was, that I was not satisfied with the threshold and the ratios.
So I went to compare the pushbutton values and to make some changes.  (I already work on that. :) )
Than I remembered that I got that schematics somewhere and finally I posted them here and made the pictures to come closer to the real one. But who knows maybe they were new the same like my clone. :)
What I can for sure say is that we are very very  close to the real ones.
Sure there is a difference but I think I cannot seriously compare them until I have not recapped the old units. Now my clone has more top end and smooth . The originals act a bit more harder.......they are more pumping with slow attack and release values.
Finally I can say that in a couple of days when all work is done. :) I will post the results.
Does somebody know where I can get those big PSU caps .?? :)
cheers
barclaycon
« Reply #77 on: January 19, 2010, 08:53:33 PM »
Thanks very much for the pictures la-2a.
Very useful and much appreciated.
Biasrocks
« Reply #78 on: January 20, 2010, 12:19:19 AM »
Thanks for the pictures La2a, very cool.
Any chance you could take a picture of the Attack and Release pots?
Mark
Neeno
« Reply #79 on: January 20, 2010, 03:16:19 AM »
Hi La-2a !
Great pictures, thank you so much !
You can source the caps from http://www.banzaimusic.com/Electrolytics/ or www.tubetown.de
I've got some Sprague Atom will fit.
Thank you very much again !
Neeno
Quote from: "CJ"
Hippies would never  kill a Llama. They might have dope crazed sex with it, but never kill it.
Quote from: "CJ"
REMEMBER, A FLUTE WITH NO HOLES, IS NOT A FLUTE, AND A DONUT WITH
Last post December 19, 2004, 10:00:25 PM
by soundguy
Last post May 13, 2008, 12:45:40 AM
by
Last post December 29, 2008, 09:22:43 AM
by Rob Flinn
Last post January 10, 2012, 12:58:29 AM
by simonsez
