SSLtech said:Is it a Bulgin connector? -I can't remember.
Thanks everyone for the helpfazeka said:Probably gotta make one, old ones when you can find them go for dumb money on eBay and many times they have frayed wire and brittle insulation.
You could opt to put in an IEC and be done with it. If the electronics are in nice shape, I'd do this:
http://ampex.hughescatalog.com/electronics/hubbell/hubbell.html
Do you have any info on how to do this mod...concerns?wkbdgeorge said:One of my 351s has been modified to have a normal iec socket. I recommend doing the swap. Proprietary power cables suck. They are always lost when you need them.
fazeka said:I not sure what's so hard about it:
1) Take out the Hubbell receptacle that's in the unit now (of course, disconnect the hot and neutral to the power transformer primary). There will be a circular hole where the Hubbell was.
2) In goes the IEC (you'll have to drill two holes for the IEC to bolt up to the chassis panel - no big), wire it up accordingly. Done.
3) Pop open a Newcastle. ;D
What's your electronics experience like? Are you asking for pictures?
