Coldsnow
Tube buffer amplifier?
« on: August 06, 2009, 09:53:01 PM »
Would some of these tube buffer amplifier kits, normally used for audiofile stereo systems work as a tube stage during mixing, like in between a recorder and mixer to add tube warmth.
shabtek
Re: Tube buffer amplifier?
« Reply #1 on: August 07, 2009, 03:17:06 AM »
no
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
ChrioN
« Reply #2 on: August 07, 2009, 03:29:39 AM »
I don't think those amplifiers can handle the "pro audio" voltage swing.
"All PCB traces are curved to emulate the electrical response of point-to-point wiring" -Drip
Tubemooley
« Reply #3 on: August 07, 2009, 06:41:41 AM »
I disagree. I believe some of them will. Put up a link to one of these which you are considering. DW.
shabtek
« Reply #4 on: August 07, 2009, 01:44:56 PM »
'warmth' like some distortion? depends on circuit. hifi is usually about clean/accurate, not color/warm. especially a simple buffer srpp/totempole/follower---impedance converter/line driver
   -CJ
kambo
« Reply #5 on: August 07, 2009, 03:21:03 PM »
actually, i have just added an output attenuator to srpp to control output level...
now i can push it to 20db gain for some slight tube distortion.
i wouldnt say its a fantastic tube overdrive/distortion... but its good... but i could do without it tho..
there is already weight of the tranies i have used... using a better design wouldnt cost much more...
i would go with better circuit as shabtek suggesting... or EZ 1290 line in is pretty good at it...
kam
Coldsnow
« Reply #6 on: August 07, 2009, 05:08:14 PM »
I was actually thinking of puting a pultec filter section before this tube buffer.  After the buffer use a 1:1 transformer, then go to a solid state amp for make up.
Here is a link to:
http://cgi.ebay.com/New-Tube-buffer-amplifier-PCB-w-parts-Musical-Fidelity_W0QQitemZ120454899742QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0babe81e&_trksid=p3286.c0.m14
« Last Edit: August 07, 2009, 06:05:09 PM by Coldsnow »
Tubemooley
« Reply #7 on: August 08, 2009, 09:56:55 AM »
I would never buy that one because it's a starved plate design. He takes 12volts and voltage doubles it up to...... something..... to power the tube plate. I don't use starved plate designs. The rest of it looks pretty good. Good coupling caps. I have used tubes in my studio for a long time before I got into transistor designs. We like tubes for the harmonics they provide. Not distortion but harmonics. Yes, tubes can distort and often due. But that's not what we're seeking. I would want to see the schematic before I purchased that. Some of the guys in HK will give the schematic and some won't. I ain't gonna' buy it unless I know what the circuit is first. And watch out.... Some of those guys will pretend to not understand what you want but really do understand. Just keep hammering on them. They'll give up the goods. You could always buy that board and sh*tcan the voltage doubler and build your own high-voltage B+ supply. That's pretty easy. DW.
kambo
« Reply #8 on: August 08, 2009, 10:13:09 AM »
http://glass-ware.stores.yahoo.net/newhardware.html
they do Aikido amps... line/mic/headphone etc...
maxheadroom
« Reply #9 on: August 08, 2009, 01:57:53 PM »
freddy get ready, it's time to rocksteady
alexc
« Reply #10 on: August 08, 2009, 07:04:39 PM »
Why not try a gyraf pultec style EQ? It has a nice srpp and a filter section in front.
Or you can use just the srpp board as it is nicely self contained.
I ping therefore I am
shabtek
« Reply #11 on: August 08, 2009, 10:18:03 PM »
I believe I have that linked ebay pcb...did not build it though I do have the blue leds to light the tubes. it is starved plate I believe. thought I might hack it but the power supply is funky deriving the B+ through voltage multiplier, filaments in series...low gain tubes. topology is similar to a NYD 1bottle which is a nice clean circuit.
@maxheadroom:"no" hi-fi runs generally runs lots of negative feedback to get a nice linear transfer. it does not distort so nicely when pushed real hard.
I look at hamptone/nyd mila for o.d. crunch
   -CJ
shabtek
« Reply #12 on: August 08, 2009, 11:06:02 PM »
   -CJ
Last post September 15, 2004, 07:12:28 AM
by Svart
Last post March 09, 2005, 12:17:55 PM
by soundguy
Last post July 25, 2009, 12:54:50 PM
by JohnRoberts
Last post June 21, 2012, 02:56:41 PM
by ruffrecords
