Few quesitons for G Pultec?
Coldsnow
Ohio
Will a 1:1 600 ohm input transformer work for the input of the filter section?  I have some older sowters I'd like to use.
Also, The greater the value (n) of the cap on the high end boost, the less the K-htz value.  Is this correct?
Also, what would be the result of using an Audio taper on both the low and hi end boost as oppose to a linear on one of them (I forget which one at the moment)
Thank you very much.
Yes
Yes
what would be the result of using an Audio taper on both the low and hi end boost as oppose to a linear on one of them (I forget which one at the moment).
Low is using Log curve. Using same value Log in the place of Lin would result in a odd boost curve.
