PRR Vari-Mu powersupply question
tweedclassic
Active member
i just finished building my power supply for the 12au7 vari-mu pioneered here by PRR.
my problem is i am getting the voltages +,- 20v dc for the opamps (i need +,- 16vdc)
and the heater supply is giving me 20v dc as well(i need 12v dc).
the problem lies in the power transformer i got is a little out of spec and giving me 15.23vac instead of 12 so i am getting 20v dc on the output of the bridge rectifier.
my questing is can i knock the voltage down buy just increasing the 220 ohm resistors in the op amp power supply
and the increasing 16 ohm resistor in the  heater supply?
how would i go about calculating larger resistor sizes? (i have no electronic education more or less trial by fire i would say. but would like to know what i am doing)
would i need higher wattage resistors?
here is a link to the schematic and pcb layout i am using.
http://www.diyfactory.com/projects/diy12au7comp/diy12au7comp.htm
Kind regards
Robert
Hook up a heater. Are voltage still high?
(No, "20V" on a 12AU7 will not cause instant death. It may burn-up in days, but I suspect your supply will sag down to ~~13V, and lower when the rest is connected.)
I am making two (stereo) units to go in the same chassis using the this pcb layout.  Would it be possible to run both of them from the same power supply board?  Or should I build both pcb boards and hook them up seperately?
josh
Look at the datasheets for your tubes and opamps.  Add up the current draw for each part and then compare to the current capability of your transformer and rectifiers....
If you draw more current than your transformer can source or more than your rectifiers can handle, then no, you can't run two board from one powersupply.
Yes, if you need to do it, that is one way to do it but remember that these will start to get hotter, the more resistance you use.
Look up Ohm's law if you want to know how to figure out the voltage drop.  Another way to do it if you don't care to learn electronics theory is to hook up a 5k/5w pot as a rheostat and use that in place of the resistor.  Dial it around until you get your voltage and then measure the resistance of the rheostat.  That's your new resistor value.
if the heater supply does not drop after loading, you can play games, like his HP circuit:
massive wattage heat and resistors is not green , so we want to be "enviro-circuit" friendly", you know, make it an Obama certified circuit.
I'm jus sayin...
i just got the tubes today and the heater voltage dropped down to 12v with tube in there. as did the op amp supply dropped as well with the chips in respective places. aroung 15 or 16v.
what is going to happen if my bias voltage is not dead on 1.5v its hovering around 1.8v. after going to a pile of LED's
thanks for the reply this is a really cool project.
much respect to all the help. i am taking some circuit analysis classes this year. but i am a mechanical engineering student so i know more about levers and strength of materials. I'm just a cog in the gearbox of life.... i digress  ::)
R.
