Disclaimer: I have no more information on the Matrix DAC than what I can see from the pictures in the eBay listing. If anyone has more, please link here.
playboss said:
we have no adequate low jitter sources,
How do you know?
I can't make out all the chips in there, from the packages it's not impossible that one is an ASRC, possibly with an integrated AES receiver, possibly fed by that clock module. Admittedly if this wee beastie had an ASRC the folks at Matrix would have likely mentioned it in their marketing material.
playboss said:
[...]"upsampling" (= ASRC) [...]
Upsampling and ASRC are most definitely
not the same, and it's quite possible to have one without the other. I really hope that these are not being treated as equivalent in Marketese.
playboss said:
high frequencies are screwed once the incoming jitter is random. With the (sub)standard clock recovery, you get data correlated jitter, and that means AHARMONICS.
No.
I am not aware of
any research showing such effects occurring in common data interfaces and either analog or digital clock recovery circuits that would be applicable to audio interfacing. Sure, with specially crafted sequences and weakened (overwide) PLLs you can show some effect, but nothing that'll show up in actual equipment in actual usage scenarios. I am more than willing to be proven wrong about this by publicly published peer-reviewed research results (as opposed to sales white papers).
(Playboss, I'm not trying to pick on you, but you've made a few very broad, very strong and very unsubstantiated claims. Please back them up with hard data or show some nuance).
Having said that, I have some concerns about the Matrix DAC as shown. I'm not too happy that at least one of the converter chips looks to be no more than a few cm from the power transformer and rectifier, plus both converters are rather close to the VFD given that VFDs have a habit of spewing wideband EMI. Also, unless they've played very complex (and expensive) shielding games, the power supply return current for the digital subsystem would appear to flow through the analog subsystem, something you'd normally want to avoid.
To answer the original question: since both
professional and
HiFi are ill-defined and unprotected labels, there is no way of telling whether a randomly selected Pro converter is always better, equal or worse than a randomly selected HiFi converter. There are jewels and stinkers in either category.
JDB.
[plus the sad truth is that many of your customers'll be listening to your product on their iPod or their computer speakers, so in the end it'll have to sound good on those. And I'm sure we've all had mixes sounding great on the studio monitors but completely uninspiring on cheap consumer equipment]
