Neve Ba106 buffer schematic need
hi thanks Crusty2
were was that hiding , had been looking for a number of days for that on here and tin ta net .
I guest it is the standard 24v psu  for this?
Crusty2  ,do you know what the next card in the chain ?
thanks again
skal1
Rob Flinn said:
strangeandbouncy said:
Are you sure?
  definitely says B- as well as B+ . . . . .
I think they might mark 0v as B- on Neve diagrams.
yes , -b = ov    , i just a ran it in sim and you get about 13v out  with 5v in , good for something he he
skal1
That is the little inverter board from a 8068 EQ module.  As written previously, the EQ did not have a line in transformer- it was in the AUX module.  That board inverted and changed gain a bit to get the proper signal into the EQ circuit.
The B- IS actually 0 volts.  This happens a lot with older nomenclature.
With older bipolar circuits, there will be a V+, V-, and 0vl.
Mike
BA106 was also used as a buffer in the 1895 switching unit, pan, aux ( BCM10 ) That was the only active circuit inside the modul.
Uped the schem:
B+ 24vdc
B- 0vdc
fazer said:
Looks like an emitter follower how does that invert?
It is an emitter follower. It does not invert. It is there just to provide a low source impedance to drive the passive mix bus. It also has no gain.
