kato
Mouser now has reverse log audio taper pots
« on: August 14, 2009, 07:33:41 AM »
Maybe they always have I don't know, but the new catalog says "new product."
http://www.mouser.com/Search/Refine.aspx?Keyword=313-1550F-
This is for the search engine because I looked for a long time before finding them.
reverse log antilog audio taper mouser pot potentiometer
nielsk
Re: Mouser now has reverse log audio taper pots
« Reply #1 on: August 14, 2009, 09:03:58 AM »
Cool!
« Reply #2 on: August 14, 2009, 02:15:07 PM »
Would these be good for a 312 type circuit?
dissonantstring
« Reply #3 on: August 14, 2009, 02:25:33 PM »
you could use the 25K rev log pot for the 312 circuit (originally 22K rev log).
i've only used omeg 22K rev log pots from audio maintenance ltd. (colin / slenderchap) in my 4 channels, but there should only be a slight difference in gain with the pot rotation (if any) using the 25K rev log.
as for quality of the pot, that's for you to decide. ;)
regards,
grant
« Last Edit: August 14, 2009, 02:27:55 PM by dissonantstring »
PRR
« Reply #4 on: August 14, 2009, 03:43:16 PM »
"1,000 On Order  Estimated Ship Date 9/18/2009"
The 16mm Alphas are entirely suitable for $99 systems, but out of place on $9,999 systems. For two-bucks, they are certainly worth a try.
dissonantstring
« Reply #5 on: August 14, 2009, 04:10:40 PM »
hi PRR,
i absolutely agree.
my above post was not meant to imply that alpha pots were inferior in any way.
acutally, 80% of my builds have them as they fit within my budget.  i know they may not be as good as some other pots made of different and more robust elements and better mechanical assemblies.
my last statement was just referring to this question:
i was not clear if by good barzilianwonderboy was referring to the quality of the pot, thus my final statement.
respectfully,
grant
detonator
« Reply #6 on: August 14, 2009, 04:22:54 PM »
There's an online store in Holland who has them for quite some time, And cheap too.
http://www.newtone-online.nl/catalog/index.php?cPath=27_70
helterbelter
« Reply #7 on: August 14, 2009, 05:06:58 PM »
What ?!?!? I have never seen this site before ! And it offers a lot of goods for cheap that I can use. Thanks !
« Reply #8 on: August 14, 2009, 06:13:58 PM »
Hi, my first post here. I've recently bought components from this site http://www.musikding.de/index.php/cat/c100_rev-log-pots.html. May be useful if anyone hasn't come across it before. Infact, they seem to sell similair items, connected perhaps?
Christian
kato
« Reply #9 on: August 14, 2009, 08:08:53 PM »
Welcome P-bass Chris. Glad you're here.
pyjaman
« Reply #10 on: August 15, 2009, 02:02:39 PM »
hi,
I recently had very bad experience with alpha 16mm carbon pots. soldered 3 (absolutely new) in a guitar amp, all 3 very noisy and awfully scratchy . had to throw them away and replace them with used omegs from an old gear. No problem after that (so, my design wasn't the problem, I think...). I was so angry that I promised to myself I'll never buy cheap Alpha 16mm carbon pots again. In my whole life.
  That said, perhaps those do not match my soldering skills, and may be perfect for the price for some applications.
regards,
Laurent.
kato
« Reply #11 on: August 15, 2009, 02:22:30 PM »
Laurent, If DC is getting through to your pots, it's normal for for that to produce scratchiness in a cheaper pot with a carbon resistive element. The conductive plastic element in the Omeg will ameliorate the problem. So it doesn't mean the pots are necessarily bad on arrival, just wrong for the application. With properly blocked DC, a cheap carbon pot could work fine.
I'm not a knowledgeable engineer. I'm just repeating sh*t I've heard. In other words: I could be wrong.
mad.ax
« Reply #12 on: August 15, 2009, 04:05:04 PM »
FYI, banzaieffects.com carry a lot of rev log pots. they have ALPHAs in 9, 16, and 25mm, but also PEC, MEC, BOURNS, CTS, and ALESSANDRO.
kato
« Reply #13 on: August 25, 2009, 10:02:47 AM »
The 1ks were supposed to be in stock this week, but I just got a mouser update e-mail that they too are delayed...
313-1550F-1K             REV AUDIO 1K                   4
                        Taiwan Alpha 16mm Carbon Potentiometers
 We expect to fill the complete quantity by 09-18-09, partial quantities may be available earlier.
Last post May 28, 2005, 08:20:57 PM
by [email protected]
Last post November 10, 2006, 01:17:28 PM
by StephenGiles
Last post April 15, 2008, 11:46:11 AM
by buschfsu
Last post January 17, 2012, 10:58:48 AM
by regularjohn
