I'm racking a bunch of PM1000 channelstrips and am wondering what to do (if anything) with the 0.47uF tants that couple the preamp stage to the eq and the output of the channel fader into the line amp that drives the busses/routing. I haven't yet recapped the channels, which I plan to do, but I've wired up a few, and I've noticed that the LF could use a bit of improvement, which perhaps the recap alone will help. But I can't help feeling that 0.47u seems a rather small value for these two caps, no? I was wondering if there is a reason NOT to change these to something like 10 or 22uF instead? I'm new to the PM1000 circuit, so I'm wondering if there is something obvious that I'm missing here.
Here's a schem:
FWIW, I already changed the line output cap (c37) from 33uF to 220uF to drive a 600:600 output transformer, and still the LF is lacking a bit. Thoughts??
Thanks, and peace,
JC
