A little background...
thinking I was the SMD whizz, I got 4 layer boards made recently, and tried soldering on some 28pin SSOP devices, using my hakko soldering iron, some lead free solder and a flux pen.
I've done similar devices before, with no issue, on 2 layer boards, however, I don't think I was quite so ready to deal with 4 layer boards (something tells me that the ground plane was pulling the heat away from the soldering point).
Anyway, long story short, I managed to burn off some of the pads on the boards. (I had 2 boards made locally for $180...). I'm going to try and rescue those boards, as I soldered the other SMD devices on there perfectly (or significantly better). I suppose I'll directly wire the pins without pads to their destination, and hope like hell.
Anyway, I want to avoid this in the future, so I'd like to get some solder paste and try the skillet method.
However, I'm stuck on what kind of solder paste to buy. SRA solder has loads of different ones at:
http://store.sra-solder.com/section.php/10/1/568720496c2ee22287d056385401ccf8
I'm a little stuck on which one to buy.
for RoHs compliance, it needs to be Lead free, but all the ones without "Pb" are very high temperature, and have a nasty flux that needs washing off with hot water and detergent! (according to that website). The temptation of using lead in the solder is very strong, but these products, once i'm in low quantity production could find themselves being shipped to Europe.
Any advice on this would be very much appreciated.
