i have two Spirit Soundtracker, both showing the same issue:
Setting the gain above approx. 40db the mic-preamps become very noisy. But the noise sounds more like an oscillation. As both units show the same effect, i assume that this is a design problem. I like these uniits very much and the issue was not a problem so far, because i uses CondensorMics, but now i also want to use ribbons, and there, i need the gain....
Does anyone one of you knows about this issue, and knows about a solution ?
As Soundcraft only sells the complete ServiceManual, does anyone have the circuitdiagram of the MicPreAmp ?
Any hint is very welcome.
Thanx, Peter
