i am having a rough time also. so i am explaining it to myself online :
let us see if there is any light at the end of this tunnel
so far we have
1) B = 1379 V
2) core weight = 70 g or 0.07 kg
now we have one last method
we did the formula for B max
we did the weight method,
now the volume method,
then we will convert all 3 to db and see what they meeeeeean...
Area Product
area product is the product of the window area in the middle of our UI core
and the cross sectional area
for some reason, the xfmr engineers like it, (that means it saves time)
Ap = Wa (window area) * Ac (cross section)
both Wa and Ac are in centimeters squared, so the Ap units will be <cm.^4>
so we have all the dims already for this lam
that means we have enuff data to use the formula
but let us do the Area Product in inches first, just in case we need it later,
0.14648 inches squared (cross section from above posts)
and we also need the window area in inches,
0.9375 * 0.3125 = 0.2929 inches squared
so our Ap in inches is
0.2929 in^2 * 0.14648 in^2 =
0.0429 in^4
now metric:
0.9375 * 0.3125 = 0.2929 inches squared = 1.89 cm^2
we have our cross section already from above: 0.945030 cm^2
so just multiply the window area by that and we have our Area Product for this transformer and this lam:
0.945030 cm^2 * 1.89 cm^2 = 1.786 cm^4
so
Ap = 1.786 cm^4
and
Ap =0.0429 in^4
now there is a Volume to Area Product relationship in transformers,
it goes something like this:
V = Kv * Ap^0.75
where Kv is a constant related to core configuration,
for laminations, Kv = 19.7,
so V = 19.7 * 1.786^3/4
V = 19.7 * root 4(1.786^3)
V = 19.7 * root 4(5.697) now just take sq root twice of 5.697
V = 19.7 * 1.545 =30.4 cm^3
so we have
three four different programs to work:
1) B = 1379 V
3) volume = 30.4 cm^3
4) Area Product = Ap = 1.786 cm^4
and, those lams are actually the same as the UTC A-10, not the neve, Doh!
and the stack is about the same, so we can also use the A-10,
just read the db reading on the can, although rumor has it that it will take a bit more?
tomorrow we will conclude all this mess and come up with some solid answers, later.
