Area Product Y-6431 > Ap = 1.786 cm^4
what can we do with this number? (to see how we derived it, see above)
all kinds of cool stuff,
Volume of XFMR = Kv * Ap^3/4 where Kv = a constant for lams of 19.7
first, lets use the Y^x button on the calculator to get rid of that 3/4 power: 1.786 ^ 3/4 = 1.545
so from the area product, we can easily get the volume of copper and iron:
Vol = 19.7 * 1.786 ^3/4 = 30.43 cm^3
hey, this is easy, what about weight, you say?
Weight = Kw * Ap^3/4
for lams, the Kw constant is 68.2
Wt = 68.2 * 1.545 = 105 grams
lets go for Surface Area >
Surface Area = Ks * Ap^ 1/2
1.786 ^1/2 (square root) = 1.336, the constant Ks of lams is 41.3 , so
Surface Area = 41.3 * 1.336 = 55.2 cm^2
one more, Current Density - J
J = Kj * Ap^ -0.125
or J =Kj / Ap ^ .125 if negative exponents are not your thing, :-X
the constant for Kj for lams is 366 for a temp rise at 25 degrees
Current Density = 366 * 0.930 = 340 Amps / cm^2
so these transformer engineers have it easy, the Ap numbers for each lam are in the catalog,
all they do is plug in a constant to get all the data they need, bastards!
so your formulas and results for the UTC Y-6431
Vol = Kv * Ap^3/4
J = Kj * Ap^ -0.125
J = Kj * Ap^ -0.125
Vol = Kv * Ap^3/4
J = Kj * Ap^ -0.125
