mhelin
Re: Modular multi channel DIY AD/DA Box
« Reply #660 on: January 13, 2019, 05:25:22 PM »
Datasheet p. 19 chapter Audio serial port operation:
"... In Master mode, the BCK and LRCK clock signals are outputs, derived from the system clock input, SCKI. The BCK clock is fixed at 128fS for Single Rate sampling mode."
On the next page about the same on slave mode (I take it that its not recommended as performance may degrade).
Single rate means rates below 54 khz, ADAT wants 48khz. At 96 khz 64fs bit clock is possible.
Mikko
rkn80
« Reply #661 on: January 14, 2019, 03:51:33 PM »
Ah, ok. Well I was looking at the wrong datasheet.  :o
Anyway, I did run it with 64fs only and it worked fine.
mhelin
Re: Modular multi channel DIY AD/DA Box New
« Reply #662 on: January 14, 2019, 05:23:33 PM »
It might work well. Found a diyaudio.com thread on PCM4204 (PCM4202 really, it's 2-channel version, same restrictions apply) ADC at 48khz / 64fs with Arta screenshot:
https://www.diyaudio.com/forums/digital-line-level/144454-noisy-adc.html#post1911792
Not in master mode though. Got to build another ADC board to supply the clocks, have a pair of CS5394s with the Elektor ADC pcb left for that purpose.
« Last Edit: January 14, 2019, 05:39:23 PM by mhelin »
Mikko
Last post August 15, 2004, 10:18:05 PM
by daArry
Last post May 06, 2007, 11:42:22 PM
by SonsOfThunder
Last post January 08, 2010, 06:59:56 PM
by desol
Last post June 29, 2012, 10:45:37 AM
by john12ax7
